Home > Technical (L405) > P400E Charging
chicb
United Kingdom 2018 Range Rover Autobiography TDV6 Barossa
P400E Charging
I have just bought a 2021 Range Rover Fifty P400E & have a query regarding charging. It says the car has to be unlocked when plugging in. Does that mean it has to stay unlocked during the charging process. Surely not. Leaving the car unlocked for around 8 hours will invalidate he insurance apart from someone entering the car.
Also, is it worth getting a wall charger. My mileage is low so time to charge is not an issue. I can get a lot of charges with the granny cable for the cost of a wall box or are there any other benefits apart from speed to charge.
Post #699966 12th Sep 2024 9:30am
Martin2
No, you can lock it when you’ve plugged in.
No benefit from an EV charger other than speed and cost of charging as you’ll be able to charge overnight at 7p (using Octopus as an example). But it takes a lot of charging to recover the cost of installing a proper charger, so no point if you do low miles and aren’t thinking about a full EV any time soon. I ran a hybrid for over a year on a ‘granny charger’, fully charging the car 3-4 times a week. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #699976 12th Sep 2024 1:05pm
Baltic Blue
    Just curious, is it considered safe and acceptable to leave it plugged into a 13A socket charging in a locked garage overnight ?
    Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #699977 12th Sep 2024 1:34pm
chicb
Martin2
Thanks for explaining that it can be locked when charging. The online handbook does not tell you that.
That's what I thought about the wall charger, never recoup the installation costs. Like you 3 times a week will be all I need. Not interested in a full EV & never will be.
Regarding Octopus energy, do I have to switch all my electricity to them. Maybe a silly question but I have a fix with British gas for leccy & gas
Thanks once again for explaining it
Post #699986 12th Sep 2024 3:26pm
Martin2
British Gas have an EV tariff, which gives you cheap (8p per kWh) between midnight and 5am. Not sure if they will switch you over if you’re on a fixed tariff. It will take 6-7 hours to charge if it’s fairly empty, so you’ll get most of it in the lower rate.
It won’t just benefit charging, we run the washing machine and dishwasher and adding in the charging means 35-40% of our electricity is at 7p (the tarifff we’re on) rather than the std rate of 22.8p. Not a huge amount in the grand scheme of things, but it’s nice to pay less. The battery on my hybrid (non Range Rover) takes just under 15kwh from empty and costs £1.03 to charge, which give me 30-35 miles. So journeys on electric are only c3.5p a mile and it’s great not to have to run the petrol engine on short journeys. MY23 Panamera E-Hybrid
Post #699996 12th Sep 2024 7:15pm
chicb
£1.03 to charge, wow!!!! I checked mine yesterday on my smart meter from empty to full, £6.30 for 30 miles. Big Cry Probably better never charging & just using petrol. Never thought it would be that bad, should have gone for the 5 litre V8 which I was considering. Will see what British Gas is saying Whistle
Post #700028 13th Sep 2024 8:34am
Martin2
That doesn't sound right. What's the battery size, 13kw? That would make your tariff 48.5p per kwh, I'd have thought it was more like £3.50 to charge. MY23 Panamera E-Hybrid
Post #700030 13th Sep 2024 8:46am
chicb
Yes 13kw battery. I will double check it at next charge probably tomorrow & let you know.
Post #700033 13th Sep 2024 8:58am
chicb
Been on to British Gas, changed tariff to Electric driver v9
Off peak 12am-5am 7.9p kWh
Peak 26.00 kWh
See how it goes. Think there is a setting in the car to time it. Next problem, finding it Whistle
Found it. There is a you tube video showing it Thumbs Up
Post #700050 13th Sep 2024 11:58am
Martin2
Excellent, down to £1.50 a charge if you can set if for that window. Or less if the battery isn't flat as you'll get a higher % on the lower rate.
Having a wall charger would only save you 50p a charge, not a great return on investment! MY23 Panamera E-Hybrid
Post #700053 13th Sep 2024 12:15pm
chicb
Thanks Martin2 for keeping me on the right road. Wall charger is now a distant memory. Do you realise that you are now my "go too" Guy Thumbs Up Rolling with laughter
Post #700103 14th Sep 2024 8:44am
Martin2
Laughing Thumbs Up MY23 Panamera E-Hybrid
Post #700107 14th Sep 2024 11:19am
chicb
Here we go again Big Cry
Charged up last night, now at 30miles full charge, seemed fine, reversed out of the drive & this message popped up "Insufficient power supply to charge vehicle", thoughts please or is it me. when connecting it I flicked the power on & off a couple of times as although it was supposed to be on timed charge, it started charging immediately.
Also does anyone have an idiots guide to set up timed charging, cos I cannot get it correct.. Gone through the setup from the Censored digital handbook, (oh for the olden day's when you got a real book) but still lost. Why do you need time of departure, I only want to charge it.
Have it set to start at midnight (lightening bolt shown on screen for every day, then when setting departure time for say1pm I get the lightening bolt shown again at 1pm, don't think that's correct, or is it.
Do you have to activate anything in the car to tell it to charge a the pre determined time or does plugging in the gun activate it, cos when I switch on the power it starts charging immediately. Granny cable
Help Big Cry knew I should have got the 5 litre
Step by step idiots guide please, setting up, plugging in, switching on, everything. Where's that horse & cart.
Post #703864 6th Nov 2024 9:31am
chicb
Got it sorted with words of wisdom from someone on rrsport forum. Thanks again "jimbg" Bow down Thumbs Up
Post #704491 15th Nov 2024 10:46am
