![]() | Home > Technical (L405) > P400E Charging |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 784 ![]() ![]() |
No, you can lock it when you’ve plugged in.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 ![]() ![]() ![]() |
chicb Member Since: 27 Nov 2019 Location: Dundee Posts: 67 ![]() ![]() ![]() |
Martin2
British Gas have an EV tariff, which gives you cheap (8p per kWh) between midnight and 5am. Not sure if they will switch you over if you’re on a fixed tariff. It will take 6-7 hours to charge if it’s fairly empty, so you’ll get most of it in the lower rate.
£1.03 to charge, wow!!!! I checked mine yesterday on my smart meter from empty to full, £6.30 for 30 miles. |
That doesn't sound right. What's the battery size, 13kw? That would make your tariff 48.5p per kwh, I'd have thought it was more like £3.50 to charge. MY23 Panamera E-Hybrid
Yes 13kw battery. I will double check it at next charge probably tomorrow & let you know. |
Been on to British Gas, changed tariff to Electric driver v9
Excellent, down to £1.50 a charge if you can set if for that window. Or less if the battery isn't flat as you'll get a higher % on the lower rate.
Thanks Martin2 for keeping me on the right road. Wall charger is now a distant memory. Do you realise that you are now my "go too" Guy |
Here we go again |
Got it sorted with words of wisdom from someone on rrsport forum. Thanks again "jimbg" |
