Home > Maintenance & Mods (L405) > Upgraded front calipers. |
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 221 |
With my L405 being the 3.0TDV6, it has the small sliding calipers up front. I’ve always wanted the fixed six pot Brembo ones that the bigger engines variants have.
31st Aug 2024 10:12am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35329 |
my son has done this on his 2014 FF and says the brakes are now much better.. ... - .- -.
31st Aug 2024 10:31am |
Seeing as there seems to be some positive interest, I may as well go the whole hog and break down costings before the parcels start arriving.
31st Aug 2024 12:47pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1475 |
@kungfupanda:
2nd Sep 2024 6:42am |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 133 |
If anyone is looking to upgrade the rear here are the part numbers that I used:
2nd Sep 2024 7:26am |
And the front parts list:
2nd Sep 2024 7:31am |
You had me worried for a while! I checked the eBay listing and they’re definitely 6 pot! I picked the car up three months ago from a main dealer and before collection, they did a big service which included new flexi hoses all round. Also the front pads and discs look relatively new so hopefully everything will pop off ok. I’ve now got Brembo 380mm discs, pads, caliper bolts and caliper hardware. Just waiting on the calipers to come… |
4th Sep 2024 12:15pm |
Advisable to upgrade the rear diameters at the same time, to avoid unbalancing the brakes front to rear.
4th Sep 2024 2:52pm |
So with the rears, would I just need bigger discs and different caliper carriers. Would
4th Sep 2024 6:07pm |
AFAIK, calipers are no different, but the larger diameter disc gives more braking torque.
4th Sep 2024 7:23pm |
@kungfupanda:
4th Sep 2024 10:14pm |
5th Sep 2024 9:28am |
Just received the calipers and I’ve decided to get them fully refurbed with new bleed nipples, pistons and rubber gaskets.
7th Sep 2024 11:59am |
Just got the calipers back from the refurb company. I’m over the moon with them. Pistons were fine, they just fitted new rubber boots and bleed nipples.
24th Sep 2024 11:21am |
