Home > Maintenance & Mods (L405) > Upgraded front calipers.
Page 1 of 3 123>
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
With my L405 being the 3.0TDV6, it has the small sliding calipers up front. I’ve always wanted the fixed six pot Brembo ones that the bigger engines variants have.
Having looked into the upgrade and watched a Powerful YouTube video, it’s a simple case of taking off the old caliper and fitting the new caliper with 380mm discs and pads
I managed to source a decent looking set of calipers off EBay. Pictured here:
online gif hosting
The paint isn’t 100% perfect. I’ll inspect again once delivered and decide whether to have them fully refurbed or alternatively I may just paint them myself.
I’ve also ordered Brembo pads, new caliper bolts and pins from LR Parts.net and a pair of Brembo 380mm discs from CarParts4Less.
I’ll keep this thread going when the parts start to arrive.
Post #699171 31st Aug 2024 11:12am
my son has done this on his 2014 FF and says the brakes are now much better.. ... - .- -.
Post #699172 31st Aug 2024 11:31am
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I did exactly the same a few months ago and was very pleased with the results. A very worthwhile upgrade and now the brakes are fantastic. I upgraded the rear discs and calipers at the same time from 350mm to 365mm.
I painted the calipers black with heavy duty PU lacquer having applied some new decals. I didn’t use high temp paint and there are no issues.
Looking forward to the updates as you do the project. Thumbs Up
Post #699173 31st Aug 2024 11:36am
kungfupanda
Seeing as there seems to be some positive interest, I may as well go the whole hog and break down costings before the parcels start arriving.
Calipers from EBay £400
Brembo Pads LR Parts £124.31
Brembo Discs CarParts4Less £106.38
Non Branded Pin Kit EBay £13.45
New Caliper Bolts LR Parts £27.98
Post #699181 31st Aug 2024 1:47pm
Gremlin500
@kungfupanda:
Sorry but I think you may have ordered the wrong calipers, the ones pictured are 4-pot, not 6-pot.
EDIT: Sorry, it may just be the angle of the picture Embarassed
You will need larger discs all round, and replacement brackets for the rear calipers :-
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/IMG_4912~0.jpeg[/img]
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/IMG_0518.jpeg[/img]
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/IMG_4885.jpeg[/img]
Good idea to replace the flexible hoses at the same time, if these have not been done in the past 4 years. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #699298 2nd Sep 2024 7:42am
Alex1976
If anyone is looking to upgrade the rear here are the part numbers that I used:
LR036567 - RH calliper
LR036568 - LH calliper
LR033303 - brake disc 365mm (2)
LR002080 - disc retaining screw (2)
LR031319 - carrier retaining bolt (4)
LR147981 - brake pad set
LR033295 - wear indicator
LR036570 - carrier bracket RH
LR036572 - carrier bracket LH
LR172643 - flexi hose LH
LR172644 - flexi hose RH
Post #699301 2nd Sep 2024 8:26am
Alex1976
And the front parts list:
LR139251 RH caliper
LR139252 LH caliper
LR161894 380mm brake disc
LR160069 brake pads
LR098988 wear indicator
LR079544 RH flexi hose
LR079543 LH flexi hose
LR033274 caliper bolt
LR002080 disc retaining screw
Post #699302 2nd Sep 2024 8:31am
kungfupanda
Gremlin500 wrote:
@kungfupanda:
You had me worried for a while! I checked the eBay listing and they’re definitely 6 pot!
I picked the car up three months ago from a main dealer and before collection, they did a big service which included new flexi hoses all round. Also the front pads and discs look relatively new so hopefully everything will pop off ok.
I’ve now got Brembo 380mm discs, pads, caliper bolts and caliper hardware. Just waiting on the calipers to come…
Post #699464 4th Sep 2024 1:15pm
Gremlin500
Advisable to upgrade the rear diameters at the same time, to avoid unbalancing the brakes front to rear.
(same caliper, just need to swap the brackets to move the calipers further out from the hub) Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #699475 4th Sep 2024 3:52pm
kungfupanda
So with the rears, would I just need bigger discs and different caliper carriers. Would
I need a different sized pad or the same size?
Post #699502 4th Sep 2024 7:07pm
Gremlin500
AFAIK, calipers are no different, but the larger diameter disc gives more braking torque.
Ovbs, yes you need to change the brackets (see my pic, the old & new brackets are NOT the same, the shiny new red bracket is slightly longer than the old one) This allows the same caliper to sit further away from the hub, to account for the change in brake disc [i]radius[/i].
No, you do not need different pads, they are exactly the same, in fact nothing else would fit, if that makes sense, but I don’t recommend you re-use old pads on a new disc, even if only 10% worn.
The old engineering addage applies: “ friction is independent of surface area”.
Which means, bigger pads don’t stop any better, -they just don’t wear out so fast! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #699507 4th Sep 2024 8:23pm
Gremlin500
@kungfupanda:
Check out these 2 pics, old vs new, look at the gap between the disc and the stone guard with the smaller disc, which vanishes with the larger disc, yet the caliper still sits at the edge of the disc, due to longer “legs” of the new bracket:
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/IMG_0514.jpeg[/img]
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/IMG_0513.jpeg[/img] “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #699517 4th Sep 2024 11:14pm
kungfupanda
Post #699531 5th Sep 2024 10:28am
kungfupanda
Just received the calipers and I’ve decided to get them fully refurbed with new bleed nipples, pistons and rubber gaskets.
Just wondering whether I can keep the small black metal deflectors on the rear of the caliper or should they be taken off for the L405. I’ve read somewhere that these won’t fit for the L405 applications?
Post #699681 7th Sep 2024 12:59pm
kungfupanda
Just got the calipers back from the refurb company. I’m over the moon with them. Pistons were fine, they just fitted new rubber boots and bleed nipples.
Company are called Brake Caliper Refurbs based in Rochdale.
Post #700772 24th Sep 2024 12:21pm
Page 1 of 3 123>
