Home > Maintenance & Mods (L322) > Sticking rear brake
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Sticking rear brake
Just wanting a bit of advice.
Had new brakes, disks and pipes put on 9 months ago. Rear left break is definitely sticking as disk is very hot compared to others.
Without even looking, local garage says it will need new disks and probably caliper as it will have warped the disk. really?
is it nt just a case of wheel off, free slider or pins and re-assemble?
Post #698587 22nd Aug 2024 9:21am
Gremlin500
How can they say that without looking? Sounds like BS to me, try another garage!
If the disc is discoloured, it may well be warped.
Disc run-out and thickness needs to be checked, a piston may be seized. If you can’t deal with that confidently yourself, go to a reputable garage.
Brake discs are consumable items, just like brake pads, and need to be renewed when worn, typically every few years, depending on mileage. If parts need replacing, you will have to do both sides to be safe, never do just one side. :thumbsup:
Post #698593 22nd Aug 2024 10:03am
Merchy
I have had exactly the same problem, after a rear caliper piston seized, the disc was still in perfect condition, the disc should be checked first, NOT automatically replaced.
Plus - depending upon the carrier / caliper condition, it is also possible to overhaul these parts especially if they are relatively new.
Post #698595 22nd Aug 2024 10:28am
Gremlin500
Agree with Merchy, highly unlikely to need much if all parts only 9months old, unless mileage is taxi-like! If DIY, clean thoroughly before you begin, don’t push back a dirty piston into the seal or you may get a leak, use loads of brake cleaner.
I clean, partly strip, & re-lube all my brakes each Summer on a sunny day, -much better than having to do it when it’s freezing cold and you’re running out of daylight.
Post #698599 22nd Aug 2024 10:46am
JayGee
Re: Sticking rear brake
- maybe take it up with the garage that fitted them as they should be under a 12month warranty if the parts are faulty. 2012 TDV8 Vogue (L322)
Post #698621 22nd Aug 2024 3:18pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
How many miles have you done since the new discs and calipers were fitted?
Jim
Post #698664 23rd Aug 2024 10:41am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
You can buy callipers for around £20 for the L322 so I'd just swap out for a new calliper and go. I had this happen regularly on my old L322.
If you have an OEM calliper on the vehicle now, that is sticking, then it'd be worthwhile refurbing that with a fresh seal kit ready to put back on when the next seizure occurs. If it is a cheap aftermarket calliper then just a quick change out and throw away is best.
I got quite good at swapping out rear callipers on the L322, it'd take well under 30 minutes even when using the car jack.
Post #698666 23rd Aug 2024 11:03am
Dolphinboy
UPDATE
So the garage told me the piston is not retracting fully and caliper needs to be replaced. That also recommended replacing both sides calipers and at the same time. Disks are ok apparently.
Projected total cost was £570!! Shocked
comments?
Post #698683 23rd Aug 2024 2:43pm
Dolphinboy
Thanks for the info. Where do you get calipers for £20 from? These are the large 6 pot Brembo ones, original Calipers I think, as the whole brake system was refurbed in sept last year (pipes, disks and pads) only 6000 miles ago.
Post #698684 23rd Aug 2024 2:50pm
baz000000
Lots on eBay. They have gone up a bit in price since I last had a L322 and did the calliper swap out.
https://www.ebay.co.uk/itm/184940296146
Now £35
They are listed on the likes of Island and other LR parts places at around £45. From memory the OEM part is over £200, but it is a much better unit.
Callipers either work or they don't so replacing both is BS. Usually the NS one is the one to go as that gets more road grime thrown its way.
Post #698685 23rd Aug 2024 3:23pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Rear calipers are not 6-pot Brembo on the 4.4 TDV8!! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #698686 23rd Aug 2024 3:23pm
JMC
Now £35
These are not for the 4.4 TDV8. They are for the 3.6 TDV8.
The part you seek is LR015583 The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #698687 23rd Aug 2024 3:26pm
JMC
Used: https://www.ebay.co.uk/itm/135058710909?_ul=GB The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #698688 23rd Aug 2024 3:29pm
JMC
Reconditioned: https://www.island-4x4.co.uk/brake-caliper...23445.html The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #698689 23rd Aug 2024 3:30pm
JMC
2010-2012 4.4 TDV8 all rear brake options: https://www.island-4x4.co.uk/rear-brakes-1..._3905.html The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #698691 23rd Aug 2024 3:38pm
