Home > Maintenance & Mods (L322) > Sticking rear brake
Dolphinboy
cheers fellas. all taken on board. Thumbs Up
Post #698698 23rd Aug 2024 4:11pm
JayGee
Re: UPDATE
Dolphinboy wrote:
So the garage told me the piston is not retracting fully and caliper needs to be replaced. That also recommended replacing both sides calipers and at the same time. Disks are ok apparently.
Projected total cost was £570!! Shocked
comments?
Rolling with laughter Rolling with laughter
If this is the garage that fitted them they should be replacing them for free.
A piston not retracting would be due to it seizing in the bore due to corrosion which is difficult ( impossible) to belive if they are less than a year old. 2012 TDV8 Vogue (L322)
Post #698711 23rd Aug 2024 5:50pm
