![]() | Home > Maintenance & Mods (L322) > Sticking rear brake |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1631 ![]() ![]() ![]() |
How can they say that without looking? Sounds like BS to me, try another garage!
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1226 ![]() ![]() ![]() |
I have had exactly the same problem, after a rear caliper piston seized, the disc was still in perfect condition, the disc should be checked first, NOT automatically replaced.
Agree with Merchy, highly unlikely to need much if all parts only 9months old, unless mileage is taxi-like! If DIY, clean thoroughly before you begin, don’t push back a dirty piston into the seal or you may get a leak, use loads of brake cleaner.
- maybe take it up with the garage that fitted them as they should be under a 12month warranty if the parts are faulty. 2012 TDV8 Vogue (L322) |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
How many miles have you done since the new discs and calipers were fitted?
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 145 ![]() ![]() ![]() |
You can buy callipers for around £20 for the L322 so I'd just swap out for a new calliper and go. I had this happen regularly on my old L322.
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3204 ![]() ![]() |
So the garage told me the piston is not retracting fully and caliper needs to be replaced. That also recommended replacing both sides calipers and at the same time. Disks are ok apparently.
Thanks for the info. Where do you get calipers for £20 from? These are the large 6 pot Brembo ones, original Calipers I think, as the whole brake system was refurbed in sept last year (pipes, disks and pads) only 6000 miles ago. |
Lots on eBay. They have gone up a bit in price since I last had a L322 and did the calliper swap out.
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 779 ![]() ![]() ![]() |
Rear calipers are not 6-pot Brembo on the 4.4 TDV8!! The older I get, the more I realise that people confuse wrinkles for wisdom ![]() |
These are not for the 4.4 TDV8. They are for the 3.6 TDV8. The part you seek is LR015583 The older I get, the more I realise that people confuse wrinkles for wisdom ![]() Last edited by JMC on 23rd Aug 2024 3:38pm. Edited 1 time in total |
Used: https://www.ebay.co.uk/itm/135058710909?_ul=GB The older I get, the more I realise that people confuse wrinkles for wisdom |
Reconditioned: https://www.island-4x4.co.uk/brake-caliper...23445.html The older I get, the more I realise that people confuse wrinkles for wisdom |
2010-2012 4.4 TDV8 all rear brake options: https://www.island-4x4.co.uk/rear-brakes-1..._3905.html The older I get, the more I realise that people confuse wrinkles for wisdom |
