Home > Maintenance & Mods (L322) > caliper bracket bolt alternatives |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 400 |
this is for a 4.4 tdv8/5.0 facelift
16th Aug 2024 8:50am |
its the rear ones, i cant remember if they TRW? Its actually a sport
16th Aug 2024 11:25am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
Yes TRW for the rear. Grade on the bolt head will still be the best guide though as the same caliper is likley used on other applications. According to a quick search it will either be 8.8, 10.9 or 12.9 with the latter 2 being stronger. Also the OE bolt will likley come with a dab of thread lock. 2012 TDV8 Vogue (L322) |
16th Aug 2024 11:34am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1194 |
A good engineering supplies merchant should be able to supply you with alternatives, and if you want to add threadlock, a small bottle of this stuff is cheap and will last you ages if you keep the bottle sealed.
16th Aug 2024 4:11pm |
tbh this is what caught me out i think.
18th Aug 2024 11:27am |
Never heard of a caliper bolt working loose as the torque settings are very high (often a torque setting + an additional number of degrees of rotation) and should be enough to hold it without thread lock. You had it fall off on the road and it was only secured with 1 bolt? 2012 TDV8 Vogue (L322) |
18th Aug 2024 2:27pm |
It's two bolts for the rear and only 35nm plus 90 degree which I did a few months back now
18th Aug 2024 2:45pm |
- I should check mine as I reused the bolts but prety sure I also used threadlock as well. 2012 TDV8 Vogue (L322) |
18th Aug 2024 5:01pm |
Ended up getting the ones above and installed
21st Aug 2024 1:21pm |
