![]() | Home > Maintenance & Mods (L322) > caliper bracket bolt alternatives |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
this is for a 4.4 tdv8/5.0 facelift
its the rear ones, i cant remember if they TRW? Its actually a sport |
Yes TRW for the rear. Grade on the bolt head will still be the best guide though as the same caliper is likley used on other applications. According to a quick search it will either be 8.8, 10.9 or 12.9 with the latter 2 being stronger. Also the OE bolt will likley come with a dab of thread lock. 2012 TDV8 Vogue (L322) |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
A good engineering supplies merchant should be able to supply you with alternatives, and if you want to add threadlock, a small bottle of this stuff is cheap and will last you ages if you keep the bottle sealed.
tbh this is what caught me out i think.
Never heard of a caliper bolt working loose as the torque settings are very high (often a torque setting + an additional number of degrees of rotation) and should be enough to hold it without thread lock. You had it fall off on the road and it was only secured with 1 bolt? 2012 TDV8 Vogue (L322) |
It's two bolts for the rear and only 35nm plus 90 degree which I did a few months back now
Ended up getting the ones above and installed
