Home > Maintenance & Mods (L322) > Gearbox L322 TD6 - Reverse gear slipping
fordy
Australia 2003 Range Rover HSE Td6 Galway Green
Hi all,
My 2003 L322 TD6 has done 280,000 KLMs and has finally decided it doesn't like reverse gear.
I've changed the transmission fluid and filter but there was no improvement.
All forward gears are fine and for some reason reverse gear in low range pulls like a tractor - its just that when engaging reverse in normal high ratio mode it will move on a flat surface but on the slightest incline it slips.
Anyone experienced the same issue and if so what did you do to rectify?
Cheers
Post #698104 15th Aug 2024 6:37am
toby1
I am by no means an expert but I believe this uses the same/similar 'box as the BMW E39. It is a common fault and sadly I think it is expensive. Try searching for "E39 no reverse" or along those lines.
Let's see what others say. 2012 Vogue TDV8 in Aintree green
Post #698106 15th Aug 2024 7:36am
