Home > Maintenance & Mods (L322) > abs fault |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
corrosion on the pins of the ABS unit will trigger a whole host of faults. Pull the ABS lead out and check the pins for corrosion. |
18th Jul 2024 12:47pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 543 |
If you hook up a new ABS sensor it would only clear the faults if they were caused by a short or open circuit within the sensor itself, it wouldn't prove the sensor was actually working.
18th Jul 2024 2:28pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 386 |
Pins checked and cleaned with contact cleaner …all good.did plug in new sensor didn’t change anything error codes wouldn’t clear ,have a abs ecu on its way to me will change that Monday when I’m home |
19th Jul 2024 2:15am |
There is one thing with the abs sensor connector plugs are different colours…..the male connector on the car is blue and the female abs sensor connector is green but as it’s been on the car from me getting it I don’t think it makes a difference..or does it ? |
20th Jul 2024 3:55am |
3rd Aug 2024 10:32am |
Nobody had this problem or have any ideas ? |
6th Aug 2024 3:25am |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
I would check:
6th Aug 2024 7:42am |
hi
6th Aug 2024 11:43am |
If it turns out to be the SAS, you may be able to DIY and program / code with the IID
6th Aug 2024 11:53am |
after you saying about the sas i have been reading up more about the sas ,and from what i have read i think it is the sensor ,have watched a couple of videos and yea i bit awkward but can be done ,think it needs looking at ...........thanks for your input much appreciated i was just going round and round |
6th Aug 2024 12:41pm |
Hope you get things sorted and enjoy driving the fattie |
6th Aug 2024 12:48pm |
have checked live data and it showed +/- degrees when i turned the wheel is there another live data i should of been checking ?
9th Aug 2024 11:58am |
As far as I know +/- degrees is all what's supposed to be displayed. There should be no interruption of the data, however, as you turn from lock to lock. |
9th Aug 2024 12:01pm |
ok right so I've not missed anything .......this problem has really got me stumped aprt from the abs error codes the thing drives great just the same as before |
9th Aug 2024 12:48pm |
