Home > Maintenance & Mods (L322) > abs fault
will308f
United Kingdom 2008 Range Rover Vogue TDV8 Orkney Grey
abs fault
hi guys
ive got many error codes from transfer box -transmission -abs ecu -abs sensor and several more i think the issue is a rear abs sensor ,now my thinking is that if i get a new sensor and just plug it in without fitting (old sensor will need drilling out as normal) this should prove (after codes cleared ) if its the sensor or the abs ecu or am i way off the mark ?
thanks will 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #696425 18th Jul 2024 10:01am
Dolphinboy
corrosion on the pins of the ABS unit will trigger a whole host of faults. Pull the ABS lead out and check the pins for corrosion.
Post #696442 18th Jul 2024 1:47pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
If you hook up a new ABS sensor it would only clear the faults if they were caused by a short or open circuit within the sensor itself, it wouldn't prove the sensor was actually working.
If you try to drive the car like that it'll throw up all sorts of issues as the system will assume that wheel is locked up whilst the others are turning as that sensor is not tracking wheel rotation. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #696446 18th Jul 2024 3:28pm
will308f
Pins checked and cleaned with contact cleaner …all good.did plug in new sensor didn’t change anything error codes wouldn’t clear ,have a abs ecu on its way to me will change that Monday when I’m home 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #696470 19th Jul 2024 3:15am
will308f
There is one thing with the abs sensor connector plugs are different colours…..the male connector on the car is blue and the female abs sensor connector is green but as it’s been on the car from me getting it I don’t think it makes a difference..or does it ? 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #696534 20th Jul 2024 4:55am
will308f
right i have replaced front o/s sensor (genuine) and several faults gone how ever i’m still getting abs error codes (see photos attached) i’m a bit lost if im honest first range rover so still building up my knowledge…..any help would be much appreciated
thanks mark
Post #697320 3rd Aug 2024 11:32am
will308f
Nobody had this problem or have any ideas ? 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #697467 6th Aug 2024 4:25am
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
I would check:
-Battery
-Alternator output
-Steering Angle Sensor (calibration + live data)
-Multiplug on the ABS ECU as mentioned above and also the ABS ECU itself
Good luck
Post #697470 6th Aug 2024 8:42am
will308f
hi
battery only several months old and checks good
alternator checked and good
abs ecu has been swapped no change ,but will clean multipin again just in case
steering angle sensor has been calibrated but haven't checked live data ....will do that next.
if it is the steering angle sensor will have to see about a replacement . Thumbs Up
many thanks 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #697481 6th Aug 2024 12:43pm
vs322
If it turns out to be the SAS, you may be able to DIY and program / code with the IID Thumbs Up
You need not take apart the whole dash although you'll need to work in an awkward position in the footwell. Much easier to do with an assistant.
Post #697482 6th Aug 2024 12:53pm
will308f
after you saying about the sas i have been reading up more about the sas ,and from what i have read i think it is the sensor ,have watched a couple of videos and yea i bit awkward but can be done ,think it needs looking at ...........thanks for your input much appreciated i was just going round and round Thumbs Up 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #697486 6th Aug 2024 1:41pm
vs322
Hope you get things sorted and enjoy driving the fattie Thumbs Up
Post #697487 6th Aug 2024 1:48pm
will308f
have checked live data and it showed +/- degrees when i turned the wheel is there another live data i should of been checking ?
Post #697695 9th Aug 2024 12:58pm
vs322
As far as I know +/- degrees is all what's supposed to be displayed. There should be no interruption of the data, however, as you turn from lock to lock.
Post #697696 9th Aug 2024 1:01pm
will308f
ok right so I've not missed anything .......this problem has really got me stumped Big Cry Big Cry aprt from the abs error codes the thing drives great just the same as before 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #697700 9th Aug 2024 1:48pm
