Home > Maintenance & Mods (L322) > abs fault |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
I would start checking the wiring, starting from the engine bay. Take your time with a good torch and start from the exposed portions of the wiring under the bonnet. Then remove the acoustic cover and then the ECU box cover. Look for obvious damage and chafing.
9th Aug 2024 3:18pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 419 |
yea will do .....got to something simple well i hope ,i mean it can only be a couple of things |
9th Aug 2024 7:25pm |
right wife just txt and told me fault came back when she started the car .........i dont get it .when she gets home tonight ill check the error codes but guessing they will be the same the onlt thing ive not done is replace the sas and see if that is the problem
13th Aug 2024 11:05am |
Can't see the photos (404 error) but the SAS can indeed be faulty intermittently. |
13th Aug 2024 11:19am |
hi yea sorry was trying to delete old photos but deleted them all .....when wife gets home ill check error codes and post the sas is the only thing i haven't looked at just due to where it is but i have a replacment
13th Aug 2024 12:14pm |
collected rangie from wife this afternoon and no error codes drove home and all good i dont get it |
14th Aug 2024 5:08pm |
Granted it's a different part design, my SAS would be OK one day and another wouldn't. Seemed to do well at low ambient temperatures and almost always failed after the car was left sitting outside on a hot day... |
14th Aug 2024 5:15pm |
Looks like mine is ok in the sun …..I’m going to change it anyway if it’s started to play up it’s not going to get any better |
14th Aug 2024 8:36pm |
