![]() | Home > Maintenance & Mods (L322) > Soot levels in a PDF ? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3812 ![]() ![]() ![]() |
DPF, mine starts an Active regen at 19.2g once it gets to temperature at a steady 50mph 👍
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Many thanks Mike for your reply greatly appreciated. Took me a while to consider a possible alternative to sudden panic and I will try and pick my time to give it a bit of a run when time allows for a proper run. |
I have to confess that I also occasionally resort to giving it a forced regen with my Gap iid when a convenient shorter trip is planned.
Yes it’s a problem I have with an annual mileage at about 5000 miles a year and gaps between use. Without taking the iigap readings in between things the warnings can appear when you would rather they didn’t. You can’t have everything when you’re retired but how did we manage to go to work?
Baltic Blue
https://www.fullfatrr.com/forum/topic60984...ng+gap+iid
Dave,
In true Blue Peter style, here is one I made earlier ![]() Last weeks Don’t do it too often Dave !!! Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
Great - Many thanks Mike |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
19.7g Demands Regen
I wouldn't use a forced regen to acheive 'feel-good' soot levels. It's a last resort option and has a potential to cause permenant damage. If you are getting regular amber warnings even with sub-optimal driving cycles it's likley you have other issues which need investigating. Not convinced partial or aborted regens cause oil dilution either or that oil dilution is a real problem on the 4.4TDV8 esp if you do 5k oil changes which seem to be the consensus with most owners. 2012 TDV8 Vogue (L322) |
Many thanks for your input L322 and JG. I appreciate the figures quoted explaining the general parameters of the natural regeneration process. I recently experienced an episode of “restricted performance while also at the amber PDF level”. The restricted performance was caused by a loose return booster pipe (which caused the evidence of oil on the drive) “and” the lack of power here in the hills around here.
I've been in the quite countryside of central Ireland for the last few weeks and doing a lot of local driving on very 'local' roads where the speed limit is 30/50mph and not had an amber warning and when I looked at my soot levels and regen count it's regenerating as normal. In 3 years of ownership I've never seen even an amber warning light. 2012 TDV8 Vogue (L322) |
Enjoy your trip in the countryside and regenerations will occur unknowingly. I have had a red appear though without warning in the past once and either isn’t a problem as long as you able to have a clear run when it occurs. To be sure the biggest problem is when you are faced with the Restricted Performance issue.
