Home > Maintenance & Mods (L322) > Soot levels in a PDF ?
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Hi everyone
I’ve learned on here thankfully that the yellow warning re the PDF can be cleaned even at a “24.reading before the dreaded RED”. However does anyone know if there’s a “minimal reading “ necessary before the burn as well as the quarter full tank needed.
My reading today is 19.3 so not a problem yet but living in Somerset with the country roads etc. would be great to know if a burn can be achieved when convenient to hit the motorway. I did get a run on the M5 a few weeks ago but with lane closures both up and down it only reduced the soot level from 24.4 ish to 13 before the return home.
Either motor junction is about 10 miles from me and a planned event be a good option if that would be possible. I know too many short runs but what a L322 V8TD is!!
Thanks Dave Rolling with laughter
Post #697334 3rd Aug 2024 3:04pm
Baltic Blue
DPF, mine starts an Active regen at 19.2g once it gets to temperature at a steady 50mph 👍
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #697335 3rd Aug 2024 3:15pm
Nylands
DPF
Many thanks Mike for your reply greatly appreciated. Took me a while to consider a possible alternative to sudden panic and I will try and pick my time to give it a bit of a run when time allows for a proper run. Thumbs Up Thumbs Up
Thanks Dave
Post #697337 3rd Aug 2024 3:29pm
Baltic Blue
I have to confess that I also occasionally resort to giving it a forced regen with my Gap iid when a convenient shorter trip is planned.
I don’t like uncompleted Active regents because of oil fuel dilution issues.
Post #697338 3rd Aug 2024 3:41pm
Nylands
DPF
Yes it’s a problem I have with an annual mileage at about 5000 miles a year and gaps between use. Without taking the iigap readings in between things the warnings can appear when you would rather they didn’t. You can’t have everything when you’re retired but how did we manage to go to work?
Thanks again
Dave
Post #697343 3rd Aug 2024 5:05pm
Nylands
Baltic Blue
Hi Mike taking your point on carrying out a forced regeneration using the gap tool, can you outline the basic steps needed please? I’ve had my car a number of years now but following a recent issue with a restricted performance issues caused by a disconnected booster pipe and the yellow warning at the “same time “ that would be a useful thing to be aware of.
Fortunately the local garage sorted the pipe issue out ok but the gap option gives some piece of mind if necessary. M5 was at a standstill again the day before yesterday after another accident making the forced regeneration an option when necessary.
I appreciate your help on this Mike
Thanks Dave Bow down
Post #697388 4th Aug 2024 6:47am
Baltic Blue
https://www.fullfatrr.com/forum/topic60984...ng+gap+iid
Here is a link to one of my older posts.
Hope it helps
Cheers
Post #697392 4th Aug 2024 8:35am
Baltic Blue
Dave,
Update.
It’s included in the standard build version now, so no need to contact Gap..
In true Blue Peter style, here is one I made earlier Rolling with laughter
Last weeks
Don’t do it too often Dave !!!
Post #697393 4th Aug 2024 8:42am
Nylands
DPF regeneration
Great - Many thanks Mike Thumbs Up Thumbs Up
Have a good day!
Dave
Post #697396 4th Aug 2024 9:26am
Range Rover L322
19.7g Demands Regen
23.3g Amber Warning On
27.5g Red Warning On
17.46g Amber Warning Off
21.25g Red Warning Off
Regen starts at 37mph. I can trigger it by going over 37mph a few seconds then mine will regen in traffic or even when stopped down to about 16g.
Not every regen will get you a low reading. I think all of us at some point have over-worried with DPF anxiety due to watching the numbers...
It is best to just ignore it unless you have a problem - I have to tell myself that a lot!
Matt
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #697420 4th Aug 2024 10:31pm
JayGee
I wouldn't use a forced regen to acheive 'feel-good' soot levels. It's a last resort option and has a potential to cause permenant damage. If you are getting regular amber warnings even with sub-optimal driving cycles it's likley you have other issues which need investigating. Not convinced partial or aborted regens cause oil dilution either or that oil dilution is a real problem on the 4.4TDV8 esp if you do 5k oil changes which seem to be the consensus with most owners. 2012 TDV8 Vogue (L322)
Post #697427 5th Aug 2024 9:51am
Nylands
Many thanks for your input L322 and JG. I appreciate the figures quoted explaining the general parameters of the natural regeneration process. I recently experienced an episode of “restricted performance while also at the amber PDF level”. The restricted performance was caused by a loose return booster pipe (which caused the evidence of oil on the drive) “and” the lack of power here in the hills around here.
This combination of circumstances resulted in the question re put your foot down to start the regeneration needed or put it back into restricted performance by doing so? Fortunately the local garage checked the car for the oil leak and found booster pipe issue solving the RP problem. I was then able to get to a straight run and clear some soot.
Good to know therefore that all’s well and that I will be able to get a normal regeneration done when needed without causing havoc to traffic locally. I agree best not to become an addict to checking the soot levels although living in the countryside here does limit the prospect of a good run on a day to day basis.
Thanks everyone Rolling with laughter
Dave [/u]
Post #697429 5th Aug 2024 10:56am
JayGee
I've been in the quite countryside of central Ireland for the last few weeks and doing a lot of local driving on very 'local' roads where the speed limit is 30/50mph and not had an amber warning and when I looked at my soot levels and regen count it's regenerating as normal. In 3 years of ownership I've never seen even an amber warning light. 2012 TDV8 Vogue (L322)
Post #697430 5th Aug 2024 11:02am
Nylands
Enjoy your trip in the countryside and regenerations will occur unknowingly. I have had a red appear though without warning in the past once and either isn’t a problem as long as you able to have a clear run when it occurs. To be sure the biggest problem is when you are faced with the Restricted Performance issue.
Plenty of advice on here though if that raises its head Whistle
Cheers
Post #697448 5th Aug 2024 5:54pm
