Home > Technical (L322) > Suspension Issues advice needed
TomC-RRV8
So just over a year into my ownership the car has decided to have its first hissy fit.
The Yellow Triangle followed by Red triangle appeared saying suspension issue. I plugged in my GAP IID and got the following errors:
So I did some googling and have removed the silencer and purchased a new one for the compressor hoping this would fix the issues however, it hasn't. I am still getting the C1A13-64 fault.
I have done a live data on the voltage of the sensors and they are showing as below.
Am I right in assuming that the Front right height sensor may be faulty as it is showing below 2V where as all the others are above 2V?
My only other thought is to put a new relay in for the air suspension.
Any guidance from anyone who has had these issues and resolved them would be greatly appreciated. Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
2004 Discovery Landmark 2.5D
2003 Freelander TD4 SE
Post #696649 22nd Jul 2024 11:08am
GraemeS
The low voltage of the RF sensor is not necessarily incorrect. The LF is higher than the LR by more than the RF is lower than the RR, noting that the right sensor voltages increase and decrease in the opposite direction to the left sensors as height changes. Compare the voltages at access and off-road heights to see how they change.
Post #696675 22nd Jul 2024 8:56pm
TomC-RRV8
So just to update, I changed the relay put a new silencer on and re calibrated the suspension and fingers crossed this at present has seemed to fix the issue. Fingers crossed it remains this way.
Thanks GraemeS for your advice. Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
Post #697268 2nd Aug 2024 4:03pm
TomC-RRV8
So, that didn't fix the issue and I have now got to the bottom of the issue. The fix that was needed was to put new Exhaust Valve seal repair kit from 4x4 Air Seals which has now fixed the issue. Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
Post #698310 18th Aug 2024 3:11pm
pcourtney
and did you manage to fix the ABS fault ?
Post #698311 18th Aug 2024 3:21pm
TomC-RRV8
At present its not showing up but will keep an eye on this and let you know, I did get a lost communication with the park brake module the other day. Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
Post #698312 18th Aug 2024 3:24pm
