![]() | Home > Technical (L322) > Suspension Issues advice needed |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2647 ![]() ![]() |
The low voltage of the RF sensor is not necessarily incorrect. The LF is higher than the LR by more than the RF is lower than the RR, noting that the right sensor voltages increase and decrease in the opposite direction to the left sensors as height changes. Compare the voltages at access and off-road heights to see how they change. |
TomC-RRV8 Member Since: 18 Sep 2022 Location: Pangbourne Posts: 83 ![]() ![]() |
So just to update, I changed the relay put a new silencer on and re calibrated the suspension and fingers crossed this at present has seemed to fix the issue. Fingers crossed it remains this way.
So, that didn't fix the issue and I have now got to the bottom of the issue. The fix that was needed was to put new Exhaust Valve seal repair kit from 4x4 Air Seals which has now fixed the issue. Current
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 904 ![]() ![]() ![]() |
and did you manage to fix the ABS fault ? |
At present its not showing up but will keep an eye on this and let you know, I did get a lost communication with the park brake module the other day. Current
