Home > Technical (L322) > Non Starter.......
TDV8Graeme
Non Starter.......
Well I knew it was too good to be true - three weeks of happy RRing........ then, this morning refused to start.
Everything turns on - even the radio comes on, but just a click when pressing the start button.
Now, I know I'm asking a "how long is a piece of string" question as it could be a number of things, from starter motor to fuel pumps, but any advice on where to start looking?
It has started perfectly so far, even after being left for a while. I've not used it since Wednesday, (now Sunday).
Messages - the "low battery start the engine" warning was showing three weeks ago, but not since and I've used it quite a bit. "Water in Fuel - See Handbook" has been flashing up then disappearing after a few miles. Any clues from this?
I've not tried jumping it yet, as I can't get another car close enough to it and my jump pack as also packed up!!! ( Censored Censored )
Any advice gratefully received!
Luckily, if it comes to it, both alternator and starter motor are covered on warranty..............
Ahh the joys. Rolling Eyes
TIA
Graeme
Post #696159 14th Jul 2024 11:05am
Baltic Blue
Starter motor dirty solenoid contacts.
Lots of info on here.
Post #696160 14th Jul 2024 11:16am
TDV8Graeme
Thanks Mike,
I've been looking around on here. Sadly no quick fix to get it going it seems?
Ohhhh for the days when you could open a bonnet, find the starter motor, spray some WD40 round and whack it with a rubber mallet and off you went............ Can't even find the damn thing on this machine!
Laughing Laughing
RAC home start tomorrow - I'll just use my 26 year old Volvo for now instead.
G.
Post #696169 14th Jul 2024 12:56pm
pcourtney
Water In Fuel Error ( Restricted Mode ) - I am getting this error as well - lots of info below
https://www.fullfatrr.com/forum/topic66708.html
the genuine LR sensor harness is no longer available separately to the fuel filter assembly, but it's a cheap Ford part. The part numbers are 6C119155BE and 1685716 and can be bought for less than £40 on eBay and other online retailers Smile
Post #696175 14th Jul 2024 2:48pm
mjdronfield
Will it not start after you have tried it a few times? Not a fix I know, but seem to remember it can be an intermittent issue…. At least you can move it then…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #696181 14th Jul 2024 5:34pm
TDV8Graeme
Thank you - I've been reading around this today, of course, and it does seem they have a habit of springing back into life - but not yet!
Of course, it will the very moment the RAC man arrives tomorrow...............
Laughing
Post #696182 14th Jul 2024 5:40pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Charge your battery fully. If the starter is clicking it signifies either too low a battery voltage or dirty contacts on solenoid. Generally if this is the case a full battery will normally operate after a few attempts but decreasingly.
Dirty solenoids are a well known fault on 4.4 tdv8. The solenoid is attached to the starter which is accessible through the drivers side wheel arch after taking off some panels. There are several posts on replacement.
The only other issue may be the engine earth which is on the wheel arch behind the liner on I think the passenger side. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #696208 15th Jul 2024 9:02am
CS
My 2012 WM had this, all electrics come on but just a click when starter button pressed. The starter motor was changed and no recurrence. It's a known 322 weakness. Only Range Rovers since 1988
Post #696305 16th Jul 2024 2:35pm
TDV8Graeme
Just an update on this.
It took forever for the RAC to turn up - 26hours in all in fact, but it was a "home start" so not really inconvienced, luckily I have my always reliable 26 year old Volvo as back up.
Anyway, the excellent patrol man did a battery test - fine - and tried a boosted jump start, but still clicking, so Starter Motor it is.........
I was DELIGHTED, however, to discover that the old tricks still work........
Well I remember the days when you always carried a wood or rubber faced mallet in the car to whack the starter motor or fuel pump to get your Mini/Morris Minor/Wolseley 1500/....... going - so how pleased was I that Mr Patrol man was able to get this flashy modern box of tricks going by whacking the starter motor with a wooden mallet! Rolling with laughter Rolling with laughter
Of course, it's started fine every since - but also booked in for a replacement Starter Motor next week just to be sure - even better, replaced under the extended warranty I took on purchase of the car Very Happy Very Happy
Right - next problem please..........
Post #696567 20th Jul 2024 11:37pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Of which there will be plenty Rolling with laughter Rolling with laughter Rolling with laughter 2016 4.4 diesel
Post #696573 21st Jul 2024 7:47am
Steveg
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
It’s probably just the solenoid pack contacts. Have you checked to see if anyone does and rebuild kit? It’s a simple job, once the starter motor is out. A lot cheaper to do and you don’t have to throw the old starter motor away.
Post #696576 21st Jul 2024 8:24am
TDV8Graeme
Almost certainly just the solenoid - sadly, it seems, there is no repair kit or separate solenoid. Lots of threads about it on here. Censored
Sadly gone are the days when you had a separate Solenoid with a little rubber push button on the end! Laughing Laughing
Post #696597 21st Jul 2024 1:54pm
