Home > Technical (L322) > Non Starter....... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
Starter motor dirty solenoid contacts.
14th Jul 2024 10:16am |
TDV8Graeme Member Since: 24 Jun 2024 Location: Cumbria Posts: 12 |
Thanks Mike,
14th Jul 2024 11:56am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 819 |
Water In Fuel Error ( Restricted Mode ) - I am getting this error as well - lots of info below
14th Jul 2024 1:48pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7809 |
Will it not start after you have tried it a few times? Not a fix I know, but seem to remember it can be an intermittent issue…. At least you can move it then…..
14th Jul 2024 4:34pm |
Thank you - I've been reading around this today, of course, and it does seem they have a habit of springing back into life - but not yet!
14th Jul 2024 4:40pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 364 |
Charge your battery fully. If the starter is clicking it signifies either too low a battery voltage or dirty contacts on solenoid. Generally if this is the case a full battery will normally operate after a few attempts but decreasingly.
15th Jul 2024 8:02am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
My 2012 WM had this, all electrics come on but just a click when starter button pressed. The starter motor was changed and no recurrence. It's a known 322 weakness. Only Range Rovers since 1988 |
16th Jul 2024 1:35pm |
Just an update on this.
20th Jul 2024 10:37pm |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 186 |
Right - next problem please..........
21st Jul 2024 6:47am |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 37 |
It’s probably just the solenoid pack contacts. Have you checked to see if anyone does and rebuild kit? It’s a simple job, once the starter motor is out. A lot cheaper to do and you don’t have to throw the old starter motor away. |
21st Jul 2024 7:24am |
Almost certainly just the solenoid - sadly, it seems, there is no repair kit or separate solenoid. Lots of threads about it on here.
21st Jul 2024 12:54pm |
