Home > Technical (L322) > Forced DPF Regeneration using Gap iid.
Page 5 of 6 <123456>
Range Rover L322
JayGee wrote:
If the DPF has been gutted there would be no pressure differential across it and thus it would show zero g soot load. A new or clean DPF will flow more exhaust gas at a higher pressure differential than an old and partially ash filled one so again the point at which it needs to initiate a regeneration may be higher. Just drive and monitor it and only worry if you get warning lights.
Absolutely correct. I also agree with the sentiments on this thread to leave it alone, don't fix what's not broken!. There is a propensity to mis-diagnose issues with L322 DPFs - the technology was not perfected when they bolted them on to sate the then new emissions rules and performance is not uniform.
Here are the trigger levels:
19.7g Demands Regen. The regen demand frequency increases exponentially as soot increases from here so when it gets into the 20s it will demand more and more. I have tested this exhaustively by deliberately driving short hops. As soot increases you only need to drive over 37mph for a few seconds to trigger a regen.
Amber Warning On 23.3g
Amber Warning Off 17.46g
Red Warning On 27.5g
Red Warning Off 21.25g
I would be interested to hear how your readings continue. 31.5g inferred with performance un-affected is unusual.
231 demanded regens on 135,000 miles (so average 1 regen every 584 miles) is a low number but within tolerance if your car has been mostly open road.
Please keep us updated!
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #641150 27th Aug 2022 11:00pm
Phoenix
Gutted DPF's will set a DTC due to lack of differential pressure, you either need to have the ECM software modified or introduce a downstream pressure drop within acceptable limits (2-5 Hpa is a good differential for a low DPF load). Ash load is calculated, not measured.
Post #641152 27th Aug 2022 11:24pm
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
I’ve been chasing some error codes for a while and whilst checking some sensors, noticed the DPF remaining volume states 0 pints? What does this mean? Does it mean it’s full or is it empty? Do I need to do anything? I occasionally get a restricted performance error along with P050E, P041C and P040D codes with bank1 exhaust bank 212F/100C temps (failed??). Any thoughts??
Post #642583 10th Sep 2022 12:34pm
Baltic Blue
Sorry, no idea why, but DPF remaining volume always reads 0.
100c is default (cold) value reading for exhaust temperatures sensors.
Post #642589 10th Sep 2022 1:18pm
nambFFRR
Thanks Baltic Blue….👍
Post #642717 11th Sep 2022 9:16pm
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
Morning all,
My neighbour has just popped round (2015 Sport 3.0) as his DPF red has just come on. Am i right in thinking that I am OK to do a regen using the GAP? I just wanted to get some comfort as the GAP manual says the forced regen should only be used after a DPF replacement. Thanks all Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #696098 13th Jul 2024 12:03pm
JayGee
After a DPF replacement not after a forced regen. Be careful as the car may have other issues causing the warning. Do a full fault code check to make sure there are no sensor faults and a visual inspection of the engine to check for leaks. Also make sure they haven't added any DPF cleaner to the fuel. 2012 TDV8 Vogue (L322)
Post #696101 13th Jul 2024 12:27pm
Goldstar
Thanks for the reply. I’ll do all that first. I just wanted to confirm that I can do a forced regen without replacing the dpf which it seems is what others here have done. As it’s not my car I just want to be sure. Thanks again Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #696104 13th Jul 2024 1:13pm
Baltic Blue
Doing a forced regen to clear a red alarm is fine, but I didn’t know that was possible on a car that the iid is not Vin locked to ?
Hope it works OK.
Cheers
Post #696106 13th Jul 2024 1:39pm
Goldstar
Thanks. I read the release notes and seeems you can do quite a few things on a 2nd car inc resetting the service interval. We’ll see but if necessary I’ll just get another licence
Thanks for confirming. Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #696107 13th Jul 2024 1:41pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi all,
Sorry to drag up an old post but I’ve searched and can’t find any answers.
I left my car running while I jumped out to chat to a mate - only left it for a couple of mins and when I returned to it I had the amber DPF warning.
Having read up on here, I took it for a drive (about 25 mins), mainly over 40mph but hit roadworks a couple times. Eventually turning round and coming home, same journey back and the regen didn’t kick in.
I hooked up IID and went to the force regen mode… got the screen up and hit start. When I got to 25 mph it turned to starting regen but had to slow again at a couple of roundabouts until
I reached the dual carriageway. By this time it showed Regen Halted status. increasing my speed once on the dual carriageway, varying from 50 - 70 (ish) nothing moved off of the halted status.
I finally returned home having achieved nothing after an hour but the soot level now reads 26..!
Is there anything else I can try as I’m supposed to be taking a 200 mile drive tomorrow night (up the M11, A14, M6) but have heard once the soot level reaches 30 it can’t be fixed - just don’t want to break down on the journey.
Any ideas please ..?
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #696399 17th Jul 2024 5:17pm
Range Rover L322
Here is the protocol I would follow:
It sounds like you have a hose split and the soot produced is greater than the DPF clear. Keep your IID plugged in all the time (but don't leave it in overnight, it will drain the battery).
Firstly: I don't mean to be pedantic but I think you mean "The DPF Yellow had not cleared" rather than the regen didn't kick in.
Secondly: this is almost definitely not a DPF issue. The DPF is purely the receptacle. Don't get sucked into blaming the DPF, which, while it seems logical initially, is almost never the reason.
Notes:
The IID tool "Number of Successful regen" field is not reliable.
The IID tool "Number of Demanded regen" field is reliable.
I would go for a drive down the A120 towards Stortford with the IID Tool plugged in and the setup to watch the fields:
1) Diesel Part Filter soot concentrations - inferred.
2) Exhaust Gas Temp - Bank 1 Sensor 2. (this will go to 600º-650º when regening)
3) Number of demanded regenerations (this will tell you when the car is trying to regen).
4) Total distance. You can snapshot and get a feel for the correlations.
5) Gentle on the throttle. 50-60mph is ideal. but as soonas you boot the throttle it will interrupt the regen.
If you follow this, you will quickly learn your car's sooting and regen rates.
If your car is producing 1g of Soot (inferred) in anything less than 5 miles, you most likely have a leak.
Come back on here if you have any questions. I will try and answer tonight.
Until you have got a regen happening and the soot level coming down I would not go on a long trip.
Hope that helps.... good luck!
Post #696405 17th Jul 2024 9:06pm
comports
Thanks Range Rover
Super derailed and helpful suggestions - thank you sir..!
When I say the levels weren’t coming down… I checked the soot level after each run in IID so could confirm no regen process has kicked in.
Ironically however I had some free time so hooked up IID, not to force a then but to watch the stats. Ir seems I have a typical RR though. As soon as I left home, with the ‘dashboard’ of stats to watch and a soot level of 27.7 Shocked I reached about 30mph and noticed the 27.7 dropped to 27.5.
I joined the A12 and was diving at about 50mph watching the soot levels drop and the exhaust gas temps climb to over 600°. 13 miles later the soot level reading was 2.6…!
So a successful regen had occurred on that occasion. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #696408 17th Jul 2024 11:07pm
Range Rover L322
Cool! Sounds like you are sorted.
I forgot to mention to regen there are certain parameters which must be met - these include:
You must have over 1/4 tank of fuel.
You must be driving at over 37mph. (gently!, if you mash the throttle it stops).
When you go for your long trip, keep the IIDTool on and get a handle on it...
Also - it is not advisable to force a regen unless you absolutely need to. It is better to encourage the car to sort itself out by giving it the right conditions.
This will also help make issues more recognisable.
Good luck!
Matt 2012 L322 4.4 TDV8 AB low mileage - a peach
Post #696414 18th Jul 2024 12:32am
pcourtney
All really good info, my GAP IID is on every time I go on a motorway journey just to see that the DPF Regen is working OK, set cruise control to 65mph with a full tank, and am getting one regen per 500 miles or so.
I am coming up to 200,000 miles on my car, I was going to cut out the DPF and get it cleaned off the car last year as a preventative measure, but Richard ( who works for Launch UK ) gave me one of his DPF cleaners, you pour it into the fuel tank and it lowers the temps at which all the gunge and gunk that accumulates in the EGR, DPF and Turbos (down to 400 deg instead of 600+ ) can be expunged !
https://www.launchtech.co.uk/technical-flu...f-cleaner/
Video below of Richard explaining it better than I could
I am about to buy some more and will be adding it 2 or 3 times over the year, the results are really good, which is why I am posting more info about it, for only £20 or £30 quid over 12 months it seems to be one of the better cleaners ( much better than Revive and Wynns etc ) , and if it prolongs my DPF for another few years - then happy days Smile
Post #711181 5th Feb 2025 11:36pm
