![]() | Home > Technical (L322) > Forced DPF Regeneration using Gap iid. |
Gutted DPF's will set a DTC due to lack of differential pressure, you either need to have the ECM software modified or introduce a downstream pressure drop within acceptable limits (2-5 Hpa is a good differential for a low DPF load). Ash load is calculated, not measured. |
nambFFRR Member Since: 06 Aug 2018 Location: United Kingdom Posts: 191 ![]() ![]() ![]() |
I’ve been chasing some error codes for a while and whilst checking some sensors, noticed the DPF remaining volume states 0 pints? What does this mean? Does it mean it’s full or is it empty? Do I need to do anything? I occasionally get a restricted performance error along with P050E, P041C and P040D codes with bank1 exhaust bank 212F/100C temps (failed??). Any thoughts?? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Sorry, no idea why, but DPF remaining volume always reads 0.
Thanks Baltic Blue….👍 |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 117 ![]() ![]() |
Morning all,
After a DPF replacement not after a forced regen. Be careful as the car may have other issues causing the warning. Do a full fault code check to make sure there are no sensor faults and a visual inspection of the engine to check for leaks. Also make sure they haven't added any DPF cleaner to the fuel. 2012 TDV8 Vogue (L322) |
Thanks for the reply. I’ll do all that first. I just wanted to confirm that I can do a forced regen without replacing the dpf which it seems is what others here have done. As it’s not my car I just want to be sure. Thanks again Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
Doing a forced regen to clear a red alarm is fine, but I didn’t know that was possible on a car that the iid is not Vin locked to ?
Thanks. I read the release notes and seeems you can do quite a few things on a 2nd car inc resetting the service interval. We’ll see but if necessary I’ll just get another licence
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1747 ![]() ![]() ![]() |
Hi all,
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 ![]() ![]() |
Here is the protocol I would follow:
Firstly: I don't mean to be pedantic but I think you mean "The DPF Yellow had not cleared" rather than the regen didn't kick in. Secondly: this is almost definitely not a DPF issue. The DPF is purely the receptacle. Don't get sucked into blaming the DPF, which, while it seems logical initially, is almost never the reason. Notes: The IID tool "Number of Successful regen" field is not reliable. The IID tool "Number of Demanded regen" field is reliable. I would go for a drive down the A120 towards Stortford with the IID Tool plugged in and the setup to watch the fields: 1) Diesel Part Filter soot concentrations - inferred. 2) Exhaust Gas Temp - Bank 1 Sensor 2. (this will go to 600º-650º when regening) 3) Number of demanded regenerations (this will tell you when the car is trying to regen). 4) Total distance. You can snapshot and get a feel for the correlations. 5) Gentle on the throttle. 50-60mph is ideal. but as soonas you boot the throttle it will interrupt the regen. If you follow this, you will quickly learn your car's sooting and regen rates. If your car is producing 1g of Soot (inferred) in anything less than 5 miles, you most likely have a leak. Come back on here if you have any questions. I will try and answer tonight. Until you have got a regen happening and the soot level coming down I would not go on a long trip. Hope that helps.... good luck! . 2012 L322 4.4 TDV8 AB low mileage - a peach 1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) |
Thanks Range Rover
Cool! Sounds like you are sorted.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 841 ![]() ![]() ![]() |
All really good info, my GAP IID is on every time I go on a motorway journey just to see that the DPF Regen is working OK, set cruise control to 65mph with a full tank, and am getting one regen per 500 miles or so.
