Home > Technical (L322) > Shudder |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 147 |
Hi,
9th Jul 2024 12:17am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 673 |
Sounds like torque converter on the way out. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
9th Jul 2024 7:21am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3041 |
Try some Dr Tranny addative to see if it helps. It's a temporary fix but may put you on a while until you need to spend £££. 2012 TDV8 Vogue (L322) |
9th Jul 2024 7:44am |
Eddthedoc Member Since: 07 Jan 2024 Location: Norfolk Posts: 8 |
Thank you. It’s a bit weird TBH. I don’t tend to floor the accelerator, it does feel occasionally that the drive is trying to catch up with the engine. It kicks down without shudder and pulls uphill without shudder too.
11th Jul 2024 11:12pm |
It's a small tube of fluid (friction modifier) you squirt in through the gearbox fill plug. Won't damage the gearbox but if it stops the shudder you will know the TC is on it's way out. 2012 TDV8 Vogue (L322) |
12th Jul 2024 8:49am |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 120 |
The only time I ever had a shudder on acceleration in my old L322 was when one of the rear brake cylinders had seized. |
12th Jul 2024 9:35am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 530 |
Good point made by Baz, I had an M62 engined L322 a few years back that did the same thing and that turned out to be a rear brake calliper seizing. Drives:
12th Jul 2024 10:10am |
Easy to check by feeling the wheels after driving it. If it is seized you won't have to drive far before it heats up quite a lot so hold your hand near to feel for any heat before touching it. 2012 TDV8 Vogue (L322) |
12th Jul 2024 10:24am |
