Home > Technical (L322) > Shudder
Eddthedoc
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
Shudder
I’d be grateful for any advice here if poss. I have an 08 3.6 TDV8 Vogue SE. All I pretty good but there is a bit of transmission shudder on acceleration.
I had a gearbox megaflush done by Bodsy about 6 months ago and transfer case and both diff oils done too. The only comment he made was that there was a little more filings on the plug than normal.
The car pulls well normally but occasionally will shudder on acceleration, especially with the left-right-left of a roundabout. There is no in-car whine.
Should I be worried or is there something preventative I could be doing? I’m not doing mega miles and this car has never towed. It’s done 116k miles in total.
Thanks all
Post #695806 8th Jul 2024 9:58pm
Scouse Exile
Hi,
Does it do it under load in other circumstances, for example driving uphill?
Long long does it last, is it a bit like driving over a cats eye type feeling?
Jon
Post #695811 8th Jul 2024 11:17pm
Fox889
Sounds like torque converter on the way out. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
BMW R1200GS
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
Post #695812 9th Jul 2024 6:21am
JayGee
Try some Dr Tranny addative to see if it helps. It's a temporary fix but may put you on a while until you need to spend £££. 2012 TDV8 Vogue (L322)
Post #695814 9th Jul 2024 6:44am
Eddthedoc
Thank you. It’s a bit weird TBH. I don’t tend to floor the accelerator, it does feel occasionally that the drive is trying to catch up with the engine. It kicks down without shudder and pulls uphill without shudder too.
I can move slowly in a tight turn without shudder but if I do that at, say 30mph entering and then coming out of a roundabout then I briefly feel shudder as I accelerate away.
Where would I put tranny additive? Does it do damage more than carrying on as I am?
Post #696030 11th Jul 2024 10:12pm
JayGee
It's a small tube of fluid (friction modifier) you squirt in through the gearbox fill plug. Won't damage the gearbox but if it stops the shudder you will know the TC is on it's way out. 2012 TDV8 Vogue (L322)
Post #696037 12th Jul 2024 7:49am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
The only time I ever had a shudder on acceleration in my old L322 was when one of the rear brake cylinders had seized.
Post #696043 12th Jul 2024 8:35am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Good point made by Baz, I had an M62 engined L322 a few years back that did the same thing and that turned out to be a rear brake calliper seizing. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #696047 12th Jul 2024 9:10am
JayGee
Easy to check by feeling the wheels after driving it. If it is seized you won't have to drive far before it heats up quite a lot so hold your hand near to feel for any heat before touching it. 2012 TDV8 Vogue (L322)
Post #696048 12th Jul 2024 9:24am
