![]() | Home > Maintenance & Mods (L322) > SOLVED!!? water intrusion into rear right (OSR) area of boot |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
can the rear glass seal fail ? |
There’s a possibility it’s coming from the usual culprit, the rear upper door seal and tracking down between the body panels. I had that, albeit on the other side, many years ago cured by replacing the upper door seal.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
Hi J.,
Think I may have found the source of my slight leak into the rear right battery area.
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 400 ![]() ![]() ![]() |
Once cleaned up I’d be inclined to use windscreen mastic as it’s slightly flexible when fully cured.
This stuff:
@Scouseexile.
Just checked mine after a day and night of rain and there were a few drops on the plastic 'raincoat' I fitted but still non the wiser where it comes from. Main thing is the electronics under it were dry. 2012 TDV8 Vogue (L322) |
I’ve had slight intrusion of water into the wheel well, my local indie insisted it was the rear boot seal but I wasn’t convinced.
Well it worked! used clear sealant on the welds around the hinges and not a drop inside since! |
