Home > Maintenance & Mods (L322) > SOLVED!!? water intrusion into rear right (OSR) area of boot |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 599 |
can the rear glass seal fail ? |
15th Jun 2024 10:02pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3962 |
There’s a possibility it’s coming from the usual culprit, the rear upper door seal and tracking down between the body panels. I had that, albeit on the other side, many years ago cured by replacing the upper door seal.
16th Jun 2024 7:34am |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 326 |
Hi J.,
16th Jun 2024 9:28pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3115 |
Think I may have found the source of my slight leak into the rear right battery area.
5th Jul 2024 5:58pm |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 147 |
Once cleaned up I’d be inclined to use windscreen mastic as it’s slightly flexible when fully cured.
5th Jul 2024 6:37pm |
This stuff:
5th Jul 2024 6:40pm |
@Scouseexile.
5th Jul 2024 9:55pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3050 |
Just checked mine after a day and night of rain and there were a few drops on the plastic 'raincoat' I fitted but still non the wiser where it comes from. Main thing is the electronics under it were dry. 2012 TDV8 Vogue (L322) |
6th Jul 2024 4:30pm |
I’ve had slight intrusion of water into the wheel well, my local indie insisted it was the rear boot seal but I wasn’t convinced.
6th Jul 2024 4:50pm |
