Home > Technical (L405) > oil level not available |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3750 |
Try opening the bonnet, engine off, then double click on the cruise control cancel button.
2nd Jul 2024 12:59pm |
Monty+4 Member Since: 25 Oct 2023 Location: Argyll Posts: 8 |
Thanks for the swift reply, I have tried that but it didn't work, I couldn't find any reference to the sequence working on post 2018 facelift cars, should it? |
2nd Jul 2024 2:11pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1171 |
Mine is Facelift 2018 and this works.
2nd Jul 2024 11:41pm |
Thanks, but mine is a 2020 v6, there are no outstanding campaigns, the oil level sender and wiring are different to your v8, and this maybe why the sequence you suggest doesn't work. |
3rd Jul 2024 9:14am |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1346 |
@Monty:
3rd Jul 2024 10:52am |
I will have a look when it stops raining, thanks.[/u] |
3rd Jul 2024 11:31am |
Its finally stopped raining long enough for me to get under the car and remove the undertray and the issue is I believe resolved:
5th Jul 2024 1:01pm |
Hi Monty,
5th Jul 2024 1:50pm |
Hi Monty, see this thread (sorry!):-
5th Jul 2024 1:56pm |
:oops: Not sure if the TDV6 has the same sensor issue, can someone advise? |
5th Jul 2024 2:06pm |
Hi No I don't think it does, I believe it is a different sensor and loom. |
5th Jul 2024 2:16pm |
Hi Monty, sorry if that was a red herring, but checking online gets confusing results, and the WM on here isn’t easily searchable and seems to be V8-oriented.
5th Jul 2024 4:00pm |
