Home > Technical (L405) > oil level not available
Monty+4
United Kingdom 2019 Range Rover Autobiography TDV6 Loire Blue
Had an interim oil change recently, after about 300 miles, I checked the oil level and got the Oil level not available notice, I was away and have tried daily but still no oil level available, just had the system scanned and have the codes P250B 29, P250D37, P250B 64, P250A 38 and P250B 87. There is no notification of component failure.
I believe the independent who did the oil change drained the oil by unplugging the suction tube from the sump.
Any ideas ?
2020 model year L405 AtoB STV6
Post #695399 2nd Jul 2024 12:35pm
Baltic Blue
Try opening the bonnet, engine off, then double click on the cruise control cancel button.
Post #695403 2nd Jul 2024 12:59pm
Monty+4
Thanks for the swift reply, I have tried that but it didn't work, I couldn't find any reference to the sequence working on post 2018 facelift cars, should it?
Post #695410 2nd Jul 2024 2:11pm
Kot
Mine is Facelift 2018 and this works.
To read Oil level
Simply pull the bonnet release, get in and press the start buttton (without your foot on the brake).
Press "OK" to clear any warnings ( including'bonnet open' )- once they are clear, do the oil check as normal but when it comes up "unavailable" press 'cancel' on the cruise control twice - your oil level shows!
However it could be 375 has this been done?
https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf 2018 SE SDV8 4.4 Byron Blue
Post #695435 2nd Jul 2024 11:41pm
Monty+4
Thanks, but mine is a 2020 v6, there are no outstanding campaigns, the oil level sender and wiring are different to your v8, and this maybe why the sequence you suggest doesn't work.
Post #695443 3rd Jul 2024 9:14am
Gremlin500
@Monty:
Had similar on my 2017 when I first got it, and after much frustration my local indy found someone had unplugged the cable from the sender under the car! Simple fix, so worth checking.
Post #695457 3rd Jul 2024 10:52am
Monty+4
I will have a look when it stops raining, thanks.[/u]
Post #695461 3rd Jul 2024 11:31am
Monty+4
Its finally stopped raining long enough for me to get under the car and remove the undertray and the issue is I believe resolved:
The sensor connector was not fully engaged and was covered in oil, there is no obvious source for this oil unless it was a spill from refilling or, a spray from disconnecting the tube to drain though the sensor connector is some distance away.
Once the connector had been cleaned and properly connected, by using the open bonnet dbl click on cruise cancel, a level reading was obtained and all is back to normal..
Quite how this occurred remains a mystery.
Post #695586 5th Jul 2024 1:01pm
Gremlin500
Hi Monty,
The oil is coming through the sensor wiring, it’s a known issue.
Let me (or someone) try to find you the appropriate threads…..
There is an updated loom fix for this, bear with us….. :thumbsup:
Post #695591 5th Jul 2024 1:50pm
Gremlin500
Hi Monty, see this thread (sorry!):-
http://www.fullfatrr.com/forum/topic56693.html
Post #695592 5th Jul 2024 1:56pm
Gremlin500
:oops: Not sure if the TDV6 has the same sensor issue, can someone advise?
Post #695594 5th Jul 2024 2:06pm
Monty+4
Hi No I don't think it does, I believe it is a different sensor and loom.
Post #695595 5th Jul 2024 2:16pm
Gremlin500
Hi Monty, sorry if that was a red herring, but checking online gets confusing results, and the WM on here isn’t easily searchable and seems to be V8-oriented.
Is below what we have on the V6? and does someone know if that still plugs into the same trumpet-shaped level sender as the V8?
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/IMG_0813.jpeg[/img]
Post #695604 5th Jul 2024 4:00pm
