![]() | Home > Technical (L405) > oil level not available |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
Try opening the bonnet, engine off, then double click on the cruise control cancel button.
Monty+4 Member Since: 25 Oct 2023 Location: Argyll Posts: 12 ![]() ![]() ![]() |
Thanks for the swift reply, I have tried that but it didn't work, I couldn't find any reference to the sequence working on post 2018 facelift cars, should it? |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1314 ![]() ![]() |
Mine is Facelift 2018 and this works.
Thanks, but mine is a 2020 v6, there are no outstanding campaigns, the oil level sender and wiring are different to your v8, and this maybe why the sequence you suggest doesn't work. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1678 ![]() ![]() ![]() |
@Monty:
I will have a look when it stops raining, thanks.[/u] |
Its finally stopped raining long enough for me to get under the car and remove the undertray and the issue is I believe resolved:
Hi Monty,
Hi Monty, see this thread (sorry!):-
:oops: Not sure if the TDV6 has the same sensor issue, can someone advise? |
Hi No I don't think it does, I believe it is a different sensor and loom. |
Hi Monty, sorry if that was a red herring, but checking online gets confusing results, and the WM on here isn’t easily searchable and seems to be V8-oriented.
