Home > Technical (L405) > Transfer Case TCCM Update Issue **RESOLVED** |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2485 |
I would look at reflashing the TCCM with the version that was previously installed, assuming that GAP can supply it. |
3rd Jul 2024 8:17am |
Hallza Member Since: 04 Nov 2019 Location: Essex Posts: 8 |
At the moment GAP advised reverting is not possible
3rd Jul 2024 8:45am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1189 |
Did you have a battery charger on when you did an update as per the technical bulletin? 2017 SDV8 4.4 silicon silver AB
3rd Jul 2024 10:34am |
Not possible because the GAP tool won't load an earlier version or becuase GAP don't have the earlier version? I suspect the former as have a feeling that I've tried such a reload in my MY12 L322 with my IIDtool, in which case a SDD might not have such a restriction.
3rd Jul 2024 10:35am |
I followed guidance from the reflash email received instead of the technical bulletin & didn't have it connected to a battery charger at the time of flashing.... which now makes me wonder if it dropped voltage during the reflash! But despite the IID tool showing the reflash as success, would it be worth connecting to a charger and then trying again? |
3rd Jul 2024 2:01pm |
I assume too that GAP do not have the earlier version to reflash back. I've tried reloading a couple of times and the outcome is exactly the same. |
3rd Jul 2024 2:02pm |
Have you tried recalibrating the TC clutch and low range selector? |
4th Jul 2024 1:50am |
Thank you to GraemeS & Tinman for contributing,
4th Jul 2024 6:26pm |
Good that it was only an update glitch rather than an incompatibility issue. |
4th Jul 2024 8:50pm |
Glad to help, It was something I had seen when the technician looked at my car it would seem that any work requires good power because of the power drain when flashing. 2017 SDV8 4.4 silicon silver AB
5th Jul 2024 7:24am |
