Home > Technical (L405) > Transfer Case TCCM Update Issue **RESOLVED**
Hallza
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Hello,
I'm new to L405 ownership after four L322's! and had the low speed transfer case knock as outlined in LTB00906NAS4.
Oil flushed twice and Clutch recalibrated but having an available update via the IID Tool, though best to apply this as well.
Now since applying the update last night, the car has become an expensive paperweight whereby the Low Range light on the dash and centre consol is flashing along with Gearbox Fault displayed.
Fault codes from the IID Tool as follows,
TCCM-Transfer Case
P080A-54 (2F) Clutch position is not learnt - System programming failure - missing calibration
( on 02-07-2024 20:10:49 at 184661 km )
P183A-54 (2F) Range change mechanism failure - System programming failure - missing calibration
TCM-Transmission
U0001-81 (2F) High speed CAN communication bus - Bus signal/message failure - invalid serial data received
( on 02-07-2024 20:12:37 at 184661 km )
U0001-86 (2F) High speed CAN communication bus - Bus signal/message failure - signal is invalid
( on 02-07-2024 20:12:38 at 184661 km )
Has the TCCM module now "Bricked" causing the communication failure?
GAP are looking into this but inital response is another issue with the car than the software update although all was functioning fine prior to the update (The old saying if it "ain't broke don't fix it" has crossed my mind)
Could anyone help shed any light on this issue?
Many thanks,
Robert.
Post #695440 3rd Jul 2024 8:30am
GraemeS
Australia
I would look at reflashing the TCCM with the version that was previously installed, assuming that GAP can supply it.
Post #695445 3rd Jul 2024 9:17am
Hallza
At the moment GAP advised reverting is not possible Embarassed
Would SDD be able to re-flash with the previous version?,
Or could this be a result that other modules (i.e BCM, Gearbox etc) need reflashing to acknowledge the new TCCM file?
Post #695448 3rd Jul 2024 9:45am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Did you have a battery charger on when you did an update as per the technical bulletin? 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #695462 3rd Jul 2024 11:34am
GraemeS
Australia
Not possible because the GAP tool won't load an earlier version or becuase GAP don't have the earlier version? I suspect the former as have a feeling that I've tried such a reload in my MY12 L322 with my IIDtool, in which case a SDD might not have such a restriction.
Have you tried reloading the new s/w again?
Post #695463 3rd Jul 2024 11:35am
Hallza
I followed guidance from the reflash email received instead of the technical bulletin Embarassed & didn't have it connected to a battery charger at the time of flashing.... which now makes me wonder if it dropped voltage during the reflash!
But despite the IID tool showing the reflash as success, would it be worth connecting to a charger and then trying again?
Post #695471 3rd Jul 2024 3:01pm
Hallza
I assume too that GAP do not have the earlier version to reflash back.
I've tried reloading a couple of times and the outcome is exactly the same.
Post #695472 3rd Jul 2024 3:02pm
GraemeS
Australia
Have you tried recalibrating the TC clutch and low range selector?
Post #695498 4th Jul 2024 2:50am
Hallza
Thank you to GraemeS & Tinman for contributing,
Issue now resolved and car back to how it should be... working! Smile
Support from GAP was brilliant, Patrick resent the software to re-apply to the IID Tool, then reflashed the ECU.
From there the range position sensor could be calibrated, followed by the clutch.
I did this time have the car connected to the CTEK charger but think the software update managed to corrupt hence the issues raised.
Post #695549 4th Jul 2024 7:26pm
GraemeS
Australia
Good that it was only an update glitch rather than an incompatibility issue.
Post #695560 4th Jul 2024 9:50pm
Tinman
Glad to help, It was something I had seen when the technician looked at my car it would seem that any work requires good power because of the power drain when flashing. 2017 SDV8 4.4 silicon silver AB
Post #695567 5th Jul 2024 8:24am
