![]() | Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322 |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
not on the sender on the part that goes to the box "RANGEISM WILL NOT BE TOLERATED"
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Oh that bit......... the two terminals (no.2)on the box are for positive and negative to power it up. - it doesn't matter which way round you put them the next block of three (No 3)the middle one is earth & the left one is to the cable in the gearbox (see Matts video) the third block of three (No 4)the middle one is earth & the left one is to the cable in the gearbox (see Matts video) if you get up is down and down is up just swap the two left wires in No 3 & No4 You now have 3 earth wires that need to be connected to the cigarette lighter earth The positive in the middle of the lighter can be used for the power feed. 5.0 supercharged autobiography Gone-4.4 Vogue Lpg now unmapped 4.6 HSET Turbo Lpg mapped Gone-Defender 90 200tdi Gone - 3.9 Sprintex supercharged LPG Gone - 3.9 Vogue LPG |
The gearbox bit is fiddley!
it cant be worse than the tx unit ....i think i broke it as it was working so like a tit i decided to tidy up the solder's and i think ive damaged the circit |
Oh Pooh!
lol yeah i will be "RANGEISM WILL NOT BE TOLERATED"
It's been a long day! I took my switched feed from under the cubby box Green/white wire. 5.0 supercharged autobiography
finally a big thanks to matt dave and jonno for all there help ....ive finally got the paddles working |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
thats great news!! glad u got it all working! the delay is not that great but i didnt want anyone to say that i didnt mention it Matt |
Is there a full "How To" in t'WIKI ? (Yorkshire accent for some reason |
that would be a good idea gaz...once again thanks matt |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
Any Chance of getting another set of paddles, remote system and photographing each part, at each stage of modification?
After messing about today (cos it's Tuesday and I can ![]() On the back of the TX as you turn it over: left button Left solder point = common No connection needed Right solder point = NC 5.0 supercharged autobiography Gone-4.4 Vogue Lpg now unmapped 4.6 HSET Turbo Lpg mapped Gone-Defender 90 200tdi Gone - 3.9 Sprintex supercharged LPG Gone - 3.9 Vogue LPG |
see next thread Current vehicles
