Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322 |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
not on the sender on the part that goes to the box "RANGEISM WILL NOT BE TOLERATED"
13th Jun 2011 7:58pm |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
Oh that bit......... the two terminals (no.2)on the box are for positive and negative to power it up. - it doesn't matter which way round you put them the next block of three (No 3)the middle one is earth & the left one is to the cable in the gearbox (see Matts video) the third block of three (No 4)the middle one is earth & the left one is to the cable in the gearbox (see Matts video) if you get up is down and down is up just swap the two left wires in No 3 & No4 You now have 3 earth wires that need to be connected to the cigarette lighter earth The positive in the middle of the lighter can be used for the power feed. 5.0 supercharged autobiography Gone-4.4 Vogue Lpg now unmapped 4.6 HSET Turbo Lpg mapped Gone-Defender 90 200tdi Gone - 3.9 Sprintex supercharged LPG Gone - 3.9 Vogue LPG |
13th Jun 2011 8:14pm |
The gearbox bit is fiddley!
13th Jun 2011 8:21pm |
it cant be worse than the tx unit ....i think i broke it as it was working so like a tit i decided to tidy up the solder's and i think ive damaged the circit i think you can just buy the tx on its own "RANGEISM WILL NOT BE TOLERATED"
13th Jun 2011 8:34pm |
Oh Pooh!
13th Jun 2011 8:43pm |
lol yeah i will be "RANGEISM WILL NOT BE TOLERATED"
13th Jun 2011 9:40pm |
It's been a long day! I took my switched feed from under the cubby box Green/white wire. 5.0 supercharged autobiography
14th Jun 2011 4:21am |
finally a big thanks to matt dave and jonno for all there help ....ive finally got the paddles working great mod and as for the delay when using the wireless device its so minimal its not worth worrying about "RANGEISM WILL NOT BE TOLERATED"
20th Jun 2011 5:06pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
thats great news!! glad u got it all working! the delay is not that great but i didnt want anyone to say that i didnt mention it Matt |
20th Jun 2011 5:50pm |
Is there a full "How To" in t'WIKI ? (Yorkshire accent for some reason ) |
20th Jun 2011 5:58pm |
that would be a good idea gaz...once again thanks matt "RANGEISM WILL NOT BE TOLERATED"
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
Any Chance of getting another set of paddles, remote system and photographing each part, at each stage of modification?
20th Jun 2011 7:46pm |
After messing about today (cos it's Tuesday and I can ) I found that one wire is'nt needed. On the back of the TX as you turn it over: left button Left solder point = common No connection needed Right solder point = NC 5.0 supercharged autobiography Gone-4.4 Vogue Lpg now unmapped 4.6 HSET Turbo Lpg mapped Gone-Defender 90 200tdi Gone - 3.9 Sprintex supercharged LPG Gone - 3.9 Vogue LPG |
21st Jun 2011 6:56pm |
see next thread Current vehicles
25th Jun 2011 1:06pm |
