Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322
Page 5 of 14 <123 456 ... 121314>
pretlove
not on the sender on the part that goes to the box "RANGEISM WILL NOT BE TOLERATED"
Post #68437 13th Jun 2011 7:58pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Oh that bit.........
the two terminals (no.2)on the box are for positive and negative to power it up. - it doesn't matter which way round you put them
the next block of three (No 3)the middle one is earth & the left one is to the cable in the gearbox (see Matts video)
the third block of three (No 4)the middle one is earth & the left one is to the cable in the gearbox (see Matts video)
if you get up is down and down is up just swap the two left wires in No 3 & No4
You now have 3 earth wires that need to be connected to the cigarette lighter earth
The positive in the middle of the lighter can be used for the power feed. 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #68440 13th Jun 2011 8:14pm
Jonno
The gearbox bit is fiddley!
Confused 5.0 supercharged autobiography
Post #68441 13th Jun 2011 8:21pm
pretlove
it cant be worse than the tx unit ....i think i broke it as it was working so like a tit i decided to tidy up the solder's and i think ive damaged the circit Big Cry i think you can just buy the tx on its own "RANGEISM WILL NOT BE TOLERATED"
Post #68442 13th Jun 2011 8:34pm
Jonno
Oh Pooh!
......still at least you'll be an electronics expert by the time you get it going! Rolling with laughter 5.0 supercharged autobiography
Post #68445 13th Jun 2011 8:43pm
pretlove
lol yeah i will be "RANGEISM WILL NOT BE TOLERATED"
Post #68459 13th Jun 2011 9:40pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
you will need a ignition feed for the receiver and not power from the cig lighter as this is a permanent feed otherwise you will end up with posh paddles but a flat battery
Post #68466 13th Jun 2011 11:16pm
Jonno
It's been a long day! I took my switched feed from under the cubby box Green/white wire. 5.0 supercharged autobiography
Post #68468 14th Jun 2011 4:21am
pretlove
finally a big thanks to matt dave and jonno for all there help ....ive finally got the paddles working Thumbs Up great mod and as for the delay when using the wireless device its so minimal its not worth worrying about "RANGEISM WILL NOT BE TOLERATED"
Post #69367 20th Jun 2011 5:06pm
mattstevenson2005
thats great news!! glad u got it all working! the delay is not that great but i didnt want anyone to say that i didnt mention it
Matt
Post #69380 20th Jun 2011 5:50pm
Is there a full "How To" in t'WIKI ? (Yorkshire accent for some reason Confused )
Last edited by Gazellio @ Prestige Cars on 20th Jun 2011 5:58pm. Edited 1 time in total
Post #69384 20th Jun 2011 5:58pm
pretlove
that would be a good idea gaz...once again thanks matt Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #69385 20th Jun 2011 5:58pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Request for Matt/ Dave
Any Chance of getting another set of paddles, remote system and photographing each part, at each stage of modification?
I am even will to pay for it as I can then uses them on my V8 54 plate motor.
This would then allow clear indication and pics for others to follow easily?
I would like this on my motor and know others even with the TD6 version would probably like it too.
even a rough wiring diagram would be benificial.......
I MUST SAY GREAT WORK!!!! to Matt Dave for this excellent work again!!!
Rob Bow down Bow down Bow down Thumbs Up
Post #69411 20th Jun 2011 7:46pm
Jonno
Jonno wrote:
I did the wireless method using a maplin 2 channel gizmo.
Changing the paddle board is a bit of a nightmare and I gave up building a bridge as Matt sugested.(too small for this old man to see!)
It's far easier to connect a short piece of wire from the blue (or grey wire) to the corner of the button and just unsolder the 2 small resistors.
On the back of the TX as you turn it over:
left button
Left solder point = common
Right solder point = NC
Right button
Top left solder point =common
Bottom right solder point = NC
This info will make sense when you've got the bits
Apart from that a very satisfying mod all thanks to Matt!
After messing about today (cos it's Tuesday and I can Very Happy ) I found that one wire is'nt needed.
left button
Left solder point = common No connection needed
Right solder point = NC 5.0 supercharged autobiography
Post #69546 21st Jun 2011 6:56pm
robbo770
Aberdeen member installation of Matts FFRR Paddle system
see next thread Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #69931 25th Jun 2011 1:06pm
