![]() | Home > General (L405) > Early v late L405. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
from comments previously on here, 2017 models are a sweet spot as a lot of issues were fixed (front suspension etc.) |
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 90 ![]() ![]() ![]() |
A couple that spring to mind:
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
Which ones have the ad blu thing? Is that to be avoided (if you are looking around that’s introductory year) due to extra potential oil dilution?
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 287 ![]() ![]() ![]() |
Adblu MY16 onwards 2016 SDV8 AB |
Sundayjumper Member Since: 15 May 2024 Location: Berkshire Posts: 15 ![]() ![]() ![]() |
I'd guess mainly because one of them is four years newer ? The 2017 will likely depreciate £10k over the next four years and be worth roughly what the 2013 is now. ULEZ is a thing. Euro 6 compliance will attract a significant premium anywhere near London as it'll save £12.50 per day if you live or work inside the zone - that's a worst case of £4,562.50 pa. Even if you don't need to worry about ULEZ, Euro 6 gets you a slightly lower VED band, and then as mentioned above, from 1st April 2017 it all went totally stupid and now (once they're 5 years old) a FFRR pays the same VED as a Prius hybrid ![]() |
