Home > Technical (L322) > 2011 Range Rover 4.4 TDV8 ABS, gearbox, HDC fault, etc
Bricey21
United Kingdom 2011 Range Rover Vogue SE TDV8 Barolo Black
Hi everyone, I am going through a bit of an issue with a range rover I bought. When sitting stationary it is fine, no issues apart from the common P040D-00 code. As soon as I start driving and the car reaches the speed where the doors lock, all codes start coming up and she goes into limp mode.
Codes mainly are:
U0121-63 Lost communication with ABS control module
P279D-02 Four wheel drive range signal circuit
U121-00 Lost communication with ABS control module
U0128-00 Lost communication with parking brake module
B1C82-13 Headlamp washer relay coil circuit
U0121-00 Lost communication with ABS control module
B1D58-13 Television output circuit
P040D-00 Exhaust gas recirculation temperature sensor A - circuit high
I have looked at the TCCM and all prongs look clean with no evident corrosion, cleaned up the front main earth strap where it connects to the body under the front right wing and also replaced with a new battery fully charged and coded into the car, no change. Has anyone experienced similar after checking all that?
Post #693563 29th May 2024 1:23pm
Bricey21
So tried a few more things looking at electrical connections for corrosion but nothing so far, I drove it a bit down the road and noticed that when all the fault lights come on the speedo stays at 0 even when moving.
Post #693591 29th May 2024 8:01pm
IIRC the multiplug under the bonnet that goes to the ABS pump can let water in and corrode...
Worth a look... Thumbs Up Pete
Post #693593 29th May 2024 8:40pm
Bricey21
Thanks, I checked that and no corrosion and all of the wires "seem" intact. Will keep hunting
Post #693710 31st May 2024 8:42pm
GraemeS
You might try removing the headlight washer pump relay, being relay 1 in the auxilliary junction box, to rule out any possible impact of a faulty relay or headlight washer pump.
Can you disable drive-away locking in case the locking is causing an issue?
Post #693711 31st May 2024 9:09pm
Bricey21
Well still no joy on this, have checked all fuses, looked at as many wiring joints as I can find, tried another ABD module but still get the same issues. Had it into an Indy specialist and they are stuck and cant find the issue. Truck keeps losing comms to the abs module but cant identify the issue at all?
Post #694756 20th Jun 2024 11:11am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Sounds like the speed sensor is working fine as apart from the exhaust gas temp they look like they are related.
It's not the speed sensor itself, that triggering, it's the processing that follows that being tripped, pretty much everything that should work isn't, that could be a dodgy frayed loom or water in a plug or loom.
Did this start happening after a storm, do you have damp carpets (wiring runs through the sills), or pooling water anywhere, rear wings, etc. because it's all bus based it could be anywhere on the bus ?
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #694759 20th Jun 2024 12:00pm
Bricey21
Just an update on this one as its confusing. It has been to two leading Landrover specialists in Northern Ireland, neither could find the issue, now sitting with a knowledgeable autospark who is also stumped. They checked all the main culprits and no issues. Coincidentally there was another identical RR 4.4 brought into the autospark with exactly the same issue and same diagnosis as not sure whats causing it. That one is going back to Range Rover themselves so I am hoping to get an update on what they do to fix that one. Never had such an awkward car to find a fault on!
Post #708702 9th Jan 2025 3:15pm
AndyRoo
I think probably an earthing issue. If you check & clean the main grounding points that's a fairly simple elimination and could explain why so many systems impacted.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #708706 9th Jan 2025 3:29pm
Bricey21
Thanks Andy, I had done that before I sent it to the autospark and they rechecked them
Post #708707 9th Jan 2025 3:30pm
