Home > Technical (L322) > 2011 Range Rover 4.4 TDV8 ABS, gearbox, HDC fault, etc |
Bricey21 Member Since: 26 May 2024 Location: Belfast Posts: 5 |
So tried a few more things looking at electrical connections for corrosion but nothing so far, I drove it a bit down the road and noticed that when all the fault lights come on the speedo stays at 0 even when moving. |
29th May 2024 8:01pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8178 |
IIRC the multiplug under the bonnet that goes to the ABS pump can let water in and corrode...
29th May 2024 8:40pm |
Thanks, I checked that and no corrosion and all of the wires "seem" intact. Will keep hunting |
31st May 2024 8:42pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
You might try removing the headlight washer pump relay, being relay 1 in the auxilliary junction box, to rule out any possible impact of a faulty relay or headlight washer pump.
31st May 2024 9:09pm |
Well still no joy on this, have checked all fuses, looked at as many wiring joints as I can find, tried another ABD module but still get the same issues. Had it into an Indy specialist and they are stuck and cant find the issue. Truck keeps losing comms to the abs module but cant identify the issue at all? |
20th Jun 2024 11:11am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 538 |
Sounds like the speed sensor is working fine as apart from the exhaust gas temp they look like they are related.
20th Jun 2024 12:00pm |
