![]() | Home > Technical (L322) > 2011 Range Rover 4.4 TDV8 ABS, gearbox, HDC fault, etc |
Bricey21 Member Since: 26 May 2024 Location: Belfast Posts: 7 ![]() ![]() ![]() |
So tried a few more things looking at electrical connections for corrosion but nothing so far, I drove it a bit down the road and noticed that when all the fault lights come on the speedo stays at 0 even when moving. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8543 ![]() ![]() ![]() |
IIRC the multiplug under the bonnet that goes to the ABS pump can let water in and corrode...
Thanks, I checked that and no corrosion and all of the wires "seem" intact. Will keep hunting |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2651 ![]() ![]() |
You might try removing the headlight washer pump relay, being relay 1 in the auxilliary junction box, to rule out any possible impact of a faulty relay or headlight washer pump.
Well still no joy on this, have checked all fuses, looked at as many wiring joints as I can find, tried another ABD module but still get the same issues. Had it into an Indy specialist and they are stuck and cant find the issue. Truck keeps losing comms to the abs module but cant identify the issue at all? |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Sounds like the speed sensor is working fine as apart from the exhaust gas temp they look like they are related.
Just an update on this one as its confusing. It has been to two leading Landrover specialists in Northern Ireland, neither could find the issue, now sitting with a knowledgeable autospark who is also stumped. They checked all the main culprits and no issues. Coincidentally there was another identical RR 4.4 brought into the autospark with exactly the same issue and same diagnosis as not sure whats causing it. That one is going back to Range Rover themselves so I am hoping to get an update on what they do to fix that one. Never had such an awkward car to find a fault on! |
I think probably an earthing issue. If you check & clean the main grounding points that's a fairly simple elimination and could explain why so many systems impacted.
Thanks Andy, I had done that before I sent it to the autospark and they rechecked them |
