![]() | Home > Technical (L322) > 5HP24 missing 2nd gear |
if you do a search on the topics here for your gearbox type, and look out for a member called RRPhill, you will find lots of advice from him - he is the top man for this gearbox but I think he may have retired. |
Smyfi96 Member Since: 23 May 2024 Location: Lublin Posts: 10 ![]() ![]() |
Yes i saw.. I hope not. But maybe someone else had this problem. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Did you remove/replace the tiny nylon check balls within the valve body? There are I think two, and sometimes these wear and jam, and in my case, allow blow-by, and a lazy second gear, ie not full drive, or it might be stuck, and not allowing any drive… found within the valve body, maybe check these. There are also a couple of tiny removable stop-ends too. Check up on this subject.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
Where was the air pressure applied? Was it at the duct plate interface on the main case, shown in the photo? ![]() It’s best to check it here so that the sealing of the steel pipe is checked as well. New pipes are slightly oversized and have to be hammered into place, thereby ensuring a good seal. Re-used pipes can leak or become disconnected as they're no longer an interference fit. ![]() Phil |
Nice to see you RRPhil. |
RRPhil
You say that you rebuilt the transmission, and after the rebuild there was no 2nd gear. Did 2nd gear work before you rebuilt it, or is that the reason you stripped the transmission down in the first place?
I rebuilt transsmision because my clutch A has broken at the retaining ring and I lost drive to forward totally. (only in faliure mode).
Hello,
The one-way orifice for the E-clutch is the one identified in the diagram below as ‘01’ 27.024
I’m not sure if that’s the KV-E spool that you’ve identified but, if it is, it’s important to note that there are three different spools, depending on the transmission model number. ![]() Could you read off the last three digits of the model number from the green ID plate rivetted to the casing, and also the three digit number etched into the lower rear valve block? ![]() ![]() Phil |
Thank You for answer.
I have numer: 1058 000021
Your transmission was manufactured on 31st August 2000 so it would originally have had a 1058 198 328 (i.e. ‘328’) valve body assembly. Interesting that someone appears to have updated it to a ‘350’ unit. Can you remember which type of EDS 5 damper was installed in the duct plate i.e. either 0501 314 645 or 1068 227 039 (see photo below)? Did you replace this damper, because the earlier type (0501 314 645) was known to rupture and allow the EDS 5 pressure to escape, thereby affecting operation of the E-clutch. Hence it was replaced by the improved design.
