Home > Technical (L322) > Transfer box oil
norton
United Kingdom 2012 Range Rover Autobiography TDV8 Orkney Grey
Transfer box oil
I’ve just bought a 2012 L322 4.4 TDV8, and decided I would replace all the fluids as a precaution.
I mistakenly ordered some genuine Land Rover TF0870 special transfer box oil. I didn’t realise that this was wrong until after I put it in, but I still haven’t driven it yet.
I thought I’d get the correct oil today, and went to Advanced Factors in Southampton which a couple of reputable Land Rover specialists told me was where they get all their parts from.
They looked up the reg and gave me two bottles of oil, which I assumed was correct, but when I got home, realised was not “correct” either. It’s Febi TF-1 which seems to also be an equivalent of TF0870, rather than TF-0753. I assume this is what all the customers of the various Land Rover specialists are getting when they ask for a transfer box oil change.
Do I risk driving the car for a short time until I can get the right stuff, or is the Febi oil somehow also compatible with both types of transfer box? Or should I not drive it at all until I get the right stuff?
Post #693124 22nd May 2024 2:58pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
https://www.fullfatrr.com/forum/topic55478.html 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #693155 23rd May 2024 7:18am
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Ravenol DTF1 was the one I filled in when I changed the Transfer Box.
https://www.ravenol.de/en/product/getriebe...luid-dtf-1
Post #693157 23rd May 2024 7:57am
norton
Thanks for the responses.
I managed to get something in the end from Westway Lubricants.
A reasonable price too. £29.99 for two litres delivered next day.
I’ll drain out the wrong stuff and refill with this.
Post #693184 23rd May 2024 2:03pm
D3Jon
Re: Transfer box oil
norton wrote:
<SNIP> They looked up the reg and gave me two bottles of oil, which I assumed was correct, but when I got home, realised was not “correct” either. It’s Febi TF-1 which seems to also be an equivalent of TF0870, rather than TF-0753. I assume this is what all the customers of the various Land Rover specialists are getting when they ask for a transfer box oil change. <SNIP>
Advanced Factor's website guides the buyer to a TF0870 spec oil for the 4.4 TDV8 RR. Shocked Do they need to be made aware of this (is it an error?), or is TF0870 also ok I wonder?
With reference to the two screenshots I've marked up below, their website advises their part ref ADV903 for the transfer box fluid, which is Febi TF-1. This even says TF0870 in the description (2nd screenshot).
Not sure how this compares to the LR recommendation of TF0753, but I'd personally stick with the LR recommendation, especially after reading the other thread with RRPhil's input (who certainly knows a thing or two about gearboxes).
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #693212 23rd May 2024 7:40pm
D3Jon
While digging a little deeper on this (I need Transfer Box oil for my 2014 Disco 4 with 8 speed), I found that Wetsways TF-0870 is suitable where either TF-0870 OR TF-0753 are specified... see below:
Same for the stuff made by Ravenol, says it meets the requirements of both TF-0870 & TF-0753 specifications:
2014 Disco 4 HSE
Post #693213 23rd May 2024 8:01pm
norton
It does seem odd that Westway make a TF-0753 oil and also a TF-0870 oil that is also compatible with 0753.
I wonder how different they really are?
Post #693231 24th May 2024 8:15am
D3Jon
@Norton - I think you've made the correct choice opting for the TF-0753, and if nothing else the TF-0870 you originally put in will act as a good flushing oil!
If you've not dropped it out already, I'd run around the block (in the car of course) with it in before dropping it out!
Re. differences between the two oils --> I think we need an oil specialist to come along! Very Happy Very Happy 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #693237 24th May 2024 9:56am
norton
Funnily enough I have just dropped out the old oil and filled it. I didn’t drive it at all.. but you’re right, I maybe should have. It came out looking totally new.. a waste of good oil. I’m glad I spotted I got it wrong though. We live and learn.
At least I know it will only cost £30 to do it again if I need to!
Post #693241 24th May 2024 10:30am
