![]() | Home > Technical (L322) > Transfer box oil |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic55478.html 2016 Skoda Octavia VRS Estate
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 146 ![]() ![]() ![]() |
Ravenol DTF1 was the one I filled in when I changed the Transfer Box.
norton Member Since: 16 May 2024 Location: Salisbury Posts: 10 ![]() ![]() ![]() |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 490 ![]() ![]() |
Advanced Factor's website guides the buyer to a TF0870 spec oil for the 4.4 TDV8 RR. ![]() With reference to the two screenshots I've marked up below, their website advises their part ref ADV903 for the transfer box fluid, which is Febi TF-1. This even says TF0870 in the description (2nd screenshot). Not sure how this compares to the LR recommendation of TF0753, but I'd personally stick with the LR recommendation, especially after reading the other thread with RRPhil's input (who certainly knows a thing or two about gearboxes).
![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
While digging a little deeper on this (I need Transfer Box oil for my 2014 Disco 4 with 8 speed), I found that Wetsways TF-0870 is suitable where either TF-0870 OR TF-0753 are specified... see below:
It does seem odd that Westway make a TF-0753 oil and also a TF-0870 oil that is also compatible with 0753.
@Norton - I think you've made the correct choice opting for the TF-0753, and if nothing else the TF-0870 you originally put in will act as a good flushing oil!
Funnily enough I have just dropped out the old oil and filled it. I didn’t drive it at all.. but you’re right, I maybe should have. It came out looking totally new.. a waste of good oil. I’m glad I spotted I got it wrong though. We live and learn.
