Home > Technical (L405) > L405 SDV8 Oil in the plenum etc. Help! |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1185 |
Have you just changed the oil filter by any chance? |
21st May 2024 6:24pm |
Neil183 Member Since: 21 Dec 2016 Location: Rickmansworth Posts: 37 |
No, but it had a service not that long ago, probably done 1000 miles since.
21st May 2024 6:35pm |
There is a chance that the oil filter drain valve may have come off it's post underneath the filter. Worth taking the filter out and having a look. |
21st May 2024 8:16pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
Good shout Kevin... was just about to chirp in the same advice... |
22nd May 2024 12:43am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 413 |
Interesting... How does this lead to excessive oil getting into the throttle body / intake pipework, etc? New one on me? <<--- BTW, this is a genuine question! Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
22nd May 2024 9:11am |
I don't realy know to be honest. Someone on here did explain what happens if it's misplaced.
22nd May 2024 9:29pm |
Thanks Kevin,
23rd May 2024 9:30am |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1108 |
Bloody hell who diagnosed that Kevin? overfinch modified |
23rd May 2024 9:33am |
It's not that the oil filter is not correctly installed, it's the drain back valve that comes off it's locating post.
23rd May 2024 10:28am |
To be fair the car gave all the symptoms of blown turbo's. I discovered the problem of the valve becoming detatched and nobody seems to have mentioned before that this can happen. That's why I say to always check it is firmly in place before installing a new filter. |
23rd May 2024 12:48pm |
Gotcha! So that being dislodged, would lead to the oil filter housing draining down when the engine stopped, leading to a slightly longer time to get oil pressure when starting the engine. Not bunging up the housing drain hole must cause an excess of oil somewhere else (when the engine is running), where it must then find its way into the intake system; via possibly a crankcase vent? Rover V8's used to have this problem (especially on track with lateral G's), where the oil couldn't get back from the heads to the sump quickly enough, leading to it going out through the breather system and being ingested into the intake system. I got black flagged at Mallory Park for this very reason, with a smoke screen behind me, James Bond style! Made a temporary oil catch tank out of a thermos flask and back out for the next session! Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
23rd May 2024 1:52pm |
Turns out that the plenum had split along the seam slightly causing an air leak. Not sure if this was there before or if I damaged it cleaning to be honest...
11th Jun 2024 3:01pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3051 |
Chain rivet the seam with pop rivets or self tapping screws. The turbo hits just under 1.5bar above atmospheric so quite a lot of pressure.
11th Jun 2024 3:27pm |
Blimey, thats very inventive!!
11th Jun 2024 7:32pm |
