Home > Technical (L405) > L405 SDV8 Oil in the plenum etc. Help! |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2551 |
When the drain hole isn't plugged, lots of oil escapes flooding the breather oil extraction chamber causing oil to be passed to the turbo inlet tract.
27th Aug 2024 9:38am |
19pontiac87 Member Since: 23 Aug 2024 Location: Northallerton Posts: 2 |
Thank you GraemeS, that makes perfect sense and was pretty much along the lines of what I was thinking. |
27th Aug 2024 2:17pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 466 |
Thanks Graeme, pretty much what I thought must be happening with oil pooling high up in the engine and making it's way out through a breather.
1st Sep 2024 10:38am |
