Home > Technical (L322) > 4.4 TDV8 primary turbo giving up? |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3227 |
I still can't quite understand what this small return passage does if there is a large oil return passage in the base of the filter housing? 2012 TDV8 Vogue (L322) |
28th Oct 2023 9:58am |
Yellopin Member Since: 03 Feb 2023 Location: Telford Posts: 31 |
Cheers Kev, likewise. Jay Jag implies it returns via an oil separator and if it leaks during running it overloads the separator and excess oil is fed into the intake air flow, hence the blue smoke, who’d have known? 2011 4.4 TDV8 Autobiography Ipanema sand
28th Oct 2023 10:25am |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
What you mean? What this small return passage made for? Its made for draining oil from oil vessel when you change the filter. Is the same like beer bottle, turn it up side down and beer not flow out well because the air cant pass into the bottle. So via this channel air can pass in and oil flow down better. It will flow anyway without this channel also, but it takes long time. Or you mean what happend when this passage remain open? The answear is, this passage go via oil separator. Separator can separate oil fog, couple of drops only, not oil flow. When the engine is running, too much oil pass into separator, saparator can not separate it and oil pass straight into intake system. |
28th Oct 2023 10:57am |
Ah thanks that makes sense 😊 2012 TDV8 Vogue (L322) |
28th Oct 2023 11:34am |
Butcher Member Since: 21 Feb 2024 Location: Belarus Posts: 8 |
Now we make these rubber parts |
16th Apr 2024 1:18pm |
16th Apr 2024 1:39pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2480 |
Excellent! How can I get hold of a couple? |
16th Apr 2024 8:49pm |
Looks different to the one that I took out. Is this a new design or does the lip wear away on the original? 2012 TDV8 Vogue (L322) |
17th Apr 2024 7:42am |
When used, it turns into a pancake. Аnd the new one is just like that. |
17th Apr 2024 7:51am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 815 |
How do we get hold of some for the UK ?? |
16th May 2024 10:23pm |
Hi.What quantity? One of these days I will find out the possibility of sending with a tracking number. |
17th May 2024 7:07am |
Put them on E-Bay? 2012 TDV8 Vogue (L322) |
17th May 2024 7:13am |
This will cause difficulties for me. Payment of taxes and other things. For the sake of a dozen details.
17th May 2024 8:21am |
Try contacting the forum shop and see if they will buy a batch and sell them on;
17th May 2024 8:32am |
