Home > Technical (L322) > 4.4 TDV8 primary turbo giving up?
Page 3 of 4 <1234>
kevinp
I think I was the first one to notice the spring was loose because I get a syringe and tube to suck all the old oil out the housing and that's how I noticed it. It's a bit of a poor design really but I now lube the end of the filter to give it the best chance to not drag it off the post with friction as you tighten the filter. [ I see you are in Telford if you ever need help with anything]. Thumbs Up
Post #676703 28th Oct 2023 10:40am
JayGee
I still can't quite understand what this small return passage does if there is a large oil return passage in the base of the filter housing? 2012 TDV8 Vogue (L322)
Post #676704 28th Oct 2023 10:58am
Yellopin
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Cheers Kev, likewise. Jay Jag implies it returns via an oil separator and if it leaks during running it overloads the separator and excess oil is fed into the intake air flow, hence the blue smoke, who’d have known? 2011 4.4 TDV8 Autobiography Ipanema sand
2007 3.6 TDV8 RRS HSE Black
2003 4.6is V8 BMW X5 Black
2000 2.5 TD5 Discovery Blue
2000 1.8 Freelander Black
Post #676706 28th Oct 2023 11:25am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
What you mean? What this small return passage made for? Its made for draining oil from oil vessel when you change the filter. Is the same like beer bottle, turn it up side down and beer not flow out well because the air cant pass into the bottle. So via this channel air can pass in and oil flow down better. It will flow anyway without this channel also, but it takes long time.
Or you mean what happend when this passage remain open? The answear is, this passage go via oil separator. Separator can separate oil fog, couple of drops only, not oil flow. When the engine is running, too much oil pass into separator, saparator can not separate it and oil pass straight into intake system.
Post #676707 28th Oct 2023 11:57am
JayGee
Ah thanks that makes sense 😊 2012 TDV8 Vogue (L322)
Post #676709 28th Oct 2023 12:34pm
Butcher
2011 Range Rover Vogue 4.4 V8 Santorini Black
Now we make these rubber parts
Post #690731 16th Apr 2024 2:18pm
Butcher
[/url][/img]
Post #690732 16th Apr 2024 2:39pm
GraemeS
Australia
Excellent! How can I get hold of a couple?
Post #690769 16th Apr 2024 9:49pm
JayGee
Looks different to the one that I took out. Is this a new design or does the lip wear away on the original? 2012 TDV8 Vogue (L322)
Post #690783 17th Apr 2024 8:42am
Butcher
When used, it turns into a pancake. Аnd the new one is just like that.
Post #690784 17th Apr 2024 8:51am
pcourtney
How do we get hold of some for the UK ??
Post #692823 16th May 2024 11:23pm
Butcher
Hi.What quantity? One of these days I will find out the possibility of sending with a tracking number.
Post #692826 17th May 2024 8:07am
JayGee
Put them on E-Bay? 2012 TDV8 Vogue (L322)
Post #692828 17th May 2024 8:13am
Butcher
This will cause difficulties for me. Payment of taxes and other things. For the sake of a dozen details.
My English may not be entirely accurate.
Post #692835 17th May 2024 9:21am
JayGee
Try contacting the forum shop and see if they will buy a batch and sell them on;
shop@fnltd.co.uk 2012 TDV8 Vogue (L322)
Post #692837 17th May 2024 9:32am
Page 3 of 4 <1234>
