Home > Technical (L322) > 4.4 TDV8 primary turbo giving up?
Page 1 of 4 1234>
Yellopin
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
My 4.4 TDV8 has just started blowing blue oil smoke under general use (less than 2500rpm). I can clear it out by holding 2000 rpm whilst stationary and is good for a couple of miles but then starts a nice steady cloud behind me. I wonder if the r/h primary turbo is/has blown its seals? There are no codes and I can’t see any drastic oil consumption use from the dash. It’s on 120k but full S/H for oil changes. It doesn’t have the oil drain mod and does blow oil good when I use the secondary. I haven’t used the secondary for a while as it always changes before 2000 rpm, I’m wondering if the drain sump is full and now blowing oil through the primary under normal load? Anyone know if the drain sump can be drained without the main draining or is the sump overspill still below the main oil level so just drain them both? Anyone changed just the primary turbo if worst case scenario? I’m clutching at straws with no codes or running issues as to how the oil is getting burnt without it being turbo related?I have looked through here but can’t find any primary turbo issues.
Many thanks[/list] 2011 4.4 TDV8 Autobiography Ipanema sand
2007 3.6 TDV8 RRS HSE Black
2003 4.6is V8 BMW X5 Black
2000 2.5 TD5 Discovery Blue
2000 1.8 Freelander Black
Post #676607 27th Oct 2023 3:09pm
pcourtney
Somewhere I read that changing the oil filter can be a factor when this is happening, hope others will also chip in and give you some more ideas to pursue, but taking the filter out and double checking it is all seated properly may be one thing to double check.
Post #676609 27th Oct 2023 3:28pm
kevinp
Have you just changed the oil filter by any chance?
Post #676610 27th Oct 2023 3:30pm
DrRob
We are also seeing folks change out a pump on the front of the engine with some good results.
As above, has it just had an oil change? We are also seeing incorrectly seated oil filter housing springs.
Give us a run down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #676611 27th Oct 2023 3:40pm
DrRob
And yes, you can drain the secondary sump AFAIK without dropping the main oil. I'm sure that's the case. It's the plug that sits centrally towards rear of sump following engine sump guard removal naturally. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #676612 27th Oct 2023 3:42pm
Yellopin
Many thanks for speedy responses. No, the oil filter was changed back in August when I did the oil change.
I believe it’s on its original oil cooler as it was something I was looking for leaking along with the orings, of which there was none. So maybe an internal cooler leak getting in to combustion side? 2011 4.4 TDV8 Autobiography Ipanema sand
Post #676614 27th Oct 2023 3:43pm
DrRob
Maybe but would that not be white smoke?? Blue indicates oil burning I thought??
If you need a specialist then I've heard good things about Clarkes4Landys in Childs Ercall.
Less so for Roean Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #676618 27th Oct 2023 3:50pm
Yellopin
I have fitted a brand new LR oil scavenge/brake pump on the front of the engine (and oil pressure switch whilst it was off as it was cheap enough and so much easier to access), but made no difference to secondary oil plumes. Maybe the oil filter wasn’t sealed correctly but that was over 1k ago? Clarkes did spring to mind as I too have heard good things. I am pretty handy with doing stuff myself as I haven’t had any luck with previous local specialists (not draining turbo sumps on oil changes, if the oil was in fact changed?). Ive only used others when it’s on warranty or like the rear hyd anti roll bar on an l320 where everything you touch crumbles.
Thanks Rob, I was trying to picture the sump layout as to whether it can be drained alone. It was something I’ve meant to look into for a while. I guess that’s a quick easy try? I’ve just been out to check there was no oil in the coolant regarding oil cooler. 2011 4.4 TDV8 Autobiography Ipanema sand
Post #676621 27th Oct 2023 4:08pm
Yellopin
I’ll go and remove and check oil filter along with spring seat. Would this give a symptom of low pressure reading until it fills back up the housing if it wasn’t seated correctly? 2011 4.4 TDV8 Autobiography Ipanema sand
Post #676624 27th Oct 2023 4:14pm
JayGee
Are you getting low pressure warnings on startup? 2012 TDV8 Vogue (L322)
Post #676626 27th Oct 2023 4:40pm
Yellopin
No Jay. I have had previously where it has flashed up for a second about 10-20 seconds after start but only randomly. It did it only on cold and probably half a dozen times a month so I changed the pressure switch in case it was that. Haven’t had it for a while though. I would think I would have it if the filter was draining after fitting but I’m all wars for what is causing this oil burning that clears when not under load. 2011 4.4 TDV8 Autobiography Ipanema sand
Post #676628 27th Oct 2023 4:45pm
Yellopin
Rob this is how my spring looks. The four spring legs that are on the top right aren’t pressed on per se to the post…should they be? The spring itself is loose and could just be lifted out but appears to be in the correct orientation at my guessing as I can’t find any pics of this layout just the conventional upright spring. 2011 4.4 TDV8 Autobiography Ipanema sand
Post #676631 27th Oct 2023 5:21pm
Yellopin
With pic this time
Post #676632 27th Oct 2023 5:22pm
kevinp
The four tangs on the spring need pressing almost flat then attach to the post and tap it down with a small socket. My car had started smoking badly and this was the cause.
Post #676642 27th Oct 2023 7:10pm
Yellopin
Thanks Kevin I sort of didn’t think it was right being loose. Fingers crossed that’s what’s up with mine as I’m gutted it’s started smoking for no apparent reason. Strange how something so simple can cause it to find and burn an oil source? 2011 4.4 TDV8 Autobiography Ipanema sand
Post #676644 27th Oct 2023 7:15pm
Page 1 of 4 1234>
