Home > Maintenance & Mods (L322) > 4.4 TDV8 Turbo Oil Drain Mod £££ |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3203 |
I can drive perfectly well for months without needing to use more than 2500rpm. Others say boot it everytime you take it out and you will not get a cloud as there is no buildup. Recent evidence suggests the oil filter housing oil release valve is the real culprit and not the oil drain for the turbo so do a search on this as the fix is easy. Difficult to justify spending big money getting the 'official' fix when it's just a cosmetic issue that doesn't effect the cars running. 2012 TDV8 Vogue (L322) |
13th May 2024 4:38pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
As above, check the oil filter housing valve. Filter needs to be removed first
13th May 2024 6:33pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
Just a hypothetical question - if it could potentially be the oil filter housing, and the SDV8 in the L405 not suffering this issue, I don't see why you couldn't retrofit the SDV8 filter housing to the TDV8? 2015 Range Rover Autobiography 4.4 SDV8 |
13th May 2024 9:00pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 275 |
An alternative to “booting it” is to use the command shift paddles to change down until the revs go over 2500. It can be done on any reasonable A road. I’d suggest doing this once every couple weeks to spin up the second turbo and lube the seals. If after a couple of months you still get smoke ( and you’ve done the oil filter housing oil release valve ) then consider the drain mod… I understand the drain mod is quite expensive to do. GlenRands near Liphook have a good reputation in the Hampshire area it may be worth discussing with them. TDV8 4.4 2012 |
13th May 2024 11:08pm |
