Home > Maintenance & Mods (L322) > 4.4 TDV8 Turbo Oil Drain Mod £££
Gundry14
Hi everyone, new here.
I’ve got an L322 4.4 TDV8 and I’m getting the dreaded big cloud of white/blue smoke when I give it some beans over 2500rpm. Clear to me the issue is the oil drain for turbo unless I’m wrong.
Let’s go with the fact it is that does anyone recommend any garages in or around Hampshire? My normal LR specialist has never done one so I feel I’d rather take somewhere thats had the experience of doing it. How much am I looking at money wise for that job?
The car only poodles around and doesn’t get booted much at all and I never normally get it over 2000rpm on my daily drives. When I do however get it over 2500rpm the smoke I get from behind is horrendous. After doing that and trying again on the same journey it’s no where near as bad but you can still see a tinge of smoke.
Am I left with having to just do that mod or does anyone else have any other suggestions.
Many thanks Thumbs Up
Post #692531 13th May 2024 3:55pm
JayGee
I can drive perfectly well for months without needing to use more than 2500rpm. Others say boot it everytime you take it out and you will not get a cloud as there is no buildup. Recent evidence suggests the oil filter housing oil release valve is the real culprit and not the oil drain for the turbo so do a search on this as the fix is easy. Difficult to justify spending big money getting the 'official' fix when it's just a cosmetic issue that doesn't effect the cars running. 2012 TDV8 Vogue (L322)
Post #692535 13th May 2024 4:38pm
DrRob
As above, check the oil filter housing valve. Filter needs to be removed first
https://www.fullfatrr.com/forum/post676665.html#676665
https://www.fullfatrr.com/forum/viewtopic.php?p=676663#676663
Way cheaper and safer than drilling into the sump.
Check the valve. If it’s faulty then fix and see if smoke goes.
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #692550 13th May 2024 6:33pm
garyRR
Just a hypothetical question - if it could potentially be the oil filter housing, and the SDV8 in the L405 not suffering this issue, I don't see why you couldn't retrofit the SDV8 filter housing to the TDV8? 2015 Range Rover Autobiography 4.4 SDV8
Post #692563 13th May 2024 9:00pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Re: 4.4 TDV8 Turbo Oil Drain Mod £££
An alternative to “booting it” is to use the command shift paddles to change down until the revs go over 2500. It can be done on any reasonable A road. I’d suggest doing this once every couple weeks to spin up the second turbo and lube the seals. If after a couple of months you still get smoke ( and you’ve done the oil filter housing oil release valve ) then consider the drain mod… I understand the drain mod is quite expensive to do.
GlenRands near Liphook have a good reputation in the Hampshire area it may be worth discussing with them. TDV8 4.4 2012
Post #692572 13th May 2024 11:08pm
hydromanchris
United Kingdom 2012 Range Rover Westminster 4.4 V8 Sumatra Black
4.4 TDV8 Smoking over 2800 RPM remedy
I have a 2012 TDV8 4.4 and have managed to sort out the smoking problem without resorting to the dreaded and expensive Turbo Drain Mod.
My Car was smoking BADLY and I mean BADLY over 2800 RPM especially going up an incline. I contacted several local indipendant R/R garages and non wanted to do the work, some didn't even know what I was on about.
On this Forum there is a post from a guy who modified the turbo drain scavenge pump to increase its efficiency, if you search on here you will find it, with instructions and photos, its really easy.
The pump in question is one of two different pumps that are built into the same casing, one is the turbo scavenge pump and the other is the vacuum pump for the brake servo. It is driven by the right hand camshaft at the front of the engine.
After reading the post, I was sceptical about his claims, so i decided to experiment by buying a second hand pump for 20 quid, in case I trashed my own pump. The Mod to the pump itself is dead easy, just a small hole to be drilled inside the unit, which took about an hour with cleaning etc. and a couple of hours to swap the units over on the car. I found swapping the pumps over a bit of a trial, as I have big hands and sausage fingers!
The results are amazing and 100% effective. After a few initial bursts over 2800 RPM to clear out the accumulated oil, the smoke stopped and has never reappeared. iv'e been driving it for about 4 months now and I can cane it as hard as I like without any sign of smoke, my oil consumption has also dropped dramatically.
Any questions, please give me shout. Chris.
Post #711129 5th Feb 2025 4:05pm
