Home > In Car Electronics (L322) > Reverse camera woes
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
Reverse camera woes
Hi all,
Car is a 2007 3.6 td v8.
My reverse view camera hasn't worked for years. I have now tried to replace it with a generic unit, but it turns out that no voltage is making it to the camera. I'm getting only a fraction of a volt. Does anyone know where the power feed originates and if I should be seeing full battery voltage on the two-pin connector with engine running and reverse engaged?
Thanks!
Henrik
Post #692374 11th May 2024 5:26pm
dingg1
Exact same problem last week with me, thought just a new Chinese camera would sort it, same as last time, no joy this time 🙄
I reckon its the head unit most system at fault, fuse fine, no power to camera, have decided to give up on it.....
Interesting if anyone has a fix?
Post #692411 11th May 2024 10:35pm
garyRR
It's actually quite easy to splice into the feed and add a generic aftermarket unit which you can Tigerseal/Sikaflex in a similar location to the existing camera. You'll also find you get better quality, despite the low resolution screen. 2015 Range Rover Autobiography 4.4 SDV8
Post #692425 12th May 2024 9:41am
Henrik07
Yes, that's what I was trying to do, but it turns out I don't have power. It's probably a broken wire, but to find the fault without pulling half the car apart, I hope to find out where that feed is coming from.
Thanks
Post #692430 12th May 2024 10:22am
if you cant find the camera feed then try one from the reverse lights.. ... - .- -.
Post #692432 12th May 2024 10:53am
Henrik07
I'm actually working on that right now. I found the correct wire in the bundle under the D-pillar, so I'll splice in there.
Post #692435 12th May 2024 10:57am
Henrik07
Nope, that didn't work.
I verified that I have power to the camera, but there's not a flicker of life on the screen. It could be that my China camera is a dud, but most likely I have a problem at the head unit. It seems strange that I would have multiple faults, but it's not unheard of.
Thanks,
Henrik
Post #692441 12th May 2024 12:07pm
from memory i think you need a ntsc camera....mind you my memory is a bit Censored at the moment.. Mr. Green ... - .- -.
Post #692448 12th May 2024 1:24pm
Henrik07
Thank you. £14 NTSC camera on order Very Happy
Post #692493 12th May 2024 11:08pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Another alternative:
https://audiotechdirect.com/atd-rrlr3-reve...mount-fit/ TDV8 4.4 2012
Post #692573 14th May 2024 12:26am
