Home > In Car Electronics (L322) > Reverse camera woes |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1315 |
Exact same problem last week with me, thought just a new Chinese camera would sort it, same as last time, no joy this time 🙄
11th May 2024 10:35pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1450 |
It's actually quite easy to splice into the feed and add a generic aftermarket unit which you can Tigerseal/Sikaflex in a similar location to the existing camera. You'll also find you get better quality, despite the low resolution screen. 2015 Range Rover Autobiography 4.4 SDV8 |
12th May 2024 9:41am |
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 63 |
Yes, that's what I was trying to do, but it turns out I don't have power. It's probably a broken wire, but to find the fault without pulling half the car apart, I hope to find out where that feed is coming from.
12th May 2024 10:22am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35094 |
if you cant find the camera feed then try one from the reverse lights.. ... - .- -.
12th May 2024 10:53am |
I'm actually working on that right now. I found the correct wire in the bundle under the D-pillar, so I'll splice in there. |
12th May 2024 10:57am |
Nope, that didn't work.
12th May 2024 12:07pm |
from memory i think you need a ntsc camera....mind you my memory is a bit at the moment.. ... - .- -.
12th May 2024 1:24pm |
Thank you. £14 NTSC camera on order |
12th May 2024 11:08pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 264 |
Another alternative:
14th May 2024 12:26am |
