Home > Technical (L322) > REAR WASH/WIPE |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
+1 "RANGEISM WILL NOT BE TOLERATED"
19th Jun 2011 12:04pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
The jet nozzles are located in the wiper base. Where it's connected to the motor. Common problem is these getting plugged with crappy water. To get the wiper out turn the ignition on and put the wiper on. When it's middle of the screen turn off the ignition. Job done. I replace my wiper arm and cleaned out my water hose a few months back. Have a look back in my posts as I did a little how to. |
19th Jun 2011 12:05pm |
The jet nozzle is on the arm nut cover, possibly blocked in your case. You need to remove the rear spoiler to remove the arm although you might be able to insert a pin into the jet and clear it. There is also a non return valve at the rear which ensures the water doesn't drain all the way to the tank at the front again. |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
thanks guys, i will just have to investigate a bit more i think. Current: TDV8 (3.6) RRS HSE
19th Jun 2011 7:02pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
If you can hear the electric motor buzzing, but just no water, there'll be a blockage, usually it can be solved with a blast from an airline. I had this problem with my 2002 4.4, and my local indie got it sorted out for me. Range Rover-less at the moment - Pining! |
19th Jun 2011 7:20pm |
RupertRR Member Since: 21 Jun 2011 Location: Baldock, Hertfordshire Posts: 26 |
This was a continual problem with my rear washer - the jet was constantly blocked but could be cured with a prod from a pin or sewing needle (my wife's, not mine !!). The washer would remain clear for only a couple of goes though before it blocked up again. I had the in line filter off and cleaned it three times over the years with only temporary results. In the end I got my cordless drill out.
21st Jun 2011 7:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35263 |
good tip RUPERT..
21st Jun 2011 7:09pm |
Phil H Member Since: 17 Oct 2010 Location: Monmouthshire Posts: 34 |
Had a go at mine yesterday (sunny day). Removed everything and found nozzles blocked, put back together, still nothing. Removed wiper arm, operated wash/wipe, water jet right across the road. Removed whole assembly and couldn't see any blockages.........
23rd Jun 2011 8:10am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I have a similar problem. I can hear the motor running, but its intermittent and not constant, when I hold the stalk forward. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
23rd Jun 2011 8:52am |
Gave the nozzle end a thorough rodding (using some copper earth strand) and cleaning and after removing the wiper drive and connecting it to the mains water it finally cleared. I think it needs to be very clean as the nozzle is very constricted.
23rd Jun 2011 6:28pm |
no wi-fi in the pub then...it'll save you popping home all the time.. |
23rd Jun 2011 6:31pm |
One has to wind down from all our FFRR problems and get back into the real world now and again....hic |
23rd Jun 2011 6:42pm |
iceshj Member Since: 15 Apr 2011 Location: Southampton Posts: 16 |
I had this problem with my last FFRR and landrover denied there was a problem until I told them to get a new car out and show me that they are all like this. It turned out to be the non return valve in the rear washer line wasn't stopping the water from going back to the bottle and it just took an age for the water to eventually come out.... if any! They eventually succumb to my continual complaints and tantrums and replaced it and all was cured!
28th Jun 2011 7:30pm |
Thats one of the things my cars at the dealers for today , cost to repair £117.50 |
28th Jun 2011 9:24pm |
